Toymods » Tech & Conversions » Engine oil flush
vtm666
Engine oil flush Sun, 13 November 2005 08:49 Go to next message
hey guys
i want to put in some motul 300V oil into the engine which cost lots of $$$
just wanted to know if the nulon oil flush affects the new oil in anyway???
for example, add nulon oil flush into engine with old oil, drain and refill with new oil
if theres old oil mixed with the oil flush still in the engine, can this make the new oil change its properties like make it thin???
the stuff im using is in link below
http://www.nulon.com.au/prod_EOF_engine_oil_flush. htm
Dale_ta22
Forster NSW
Re: Engine oil flush Sun, 13 November 2005 09:19 Go to previous messageGo to next message
Whatever's left is going to be VERY diluted by the time the new oil goes in, like a drop in a bucket, hardly enough to thin the oil I would imagine.
Feel free to correct me if I'm wrong though...
Toobs
Re: Engine oil flush Sun, 13 November 2005 11:50 Go to previous messageGo to next message
Yep thats pretty much the case...
If you want to be 100% sure its gone just chuck in a fill worth of cheap multigrade oil and go for a lap around the block before adding your good oil.
When you're using the engine oil flush stuff just keep an eye on the oil pressure because if your engine / oil pump are getting on a bit your oil pressure could fall to a point that could damage the engine.
rollaboy
Coffs
Re: Engine oil flush Sun, 13 November 2005 23:25 Go to previous message
The brand Inter-Ject works great.
http://www.interject.co.nz/interject/index.html
There are some dealers for it about.
They do from fuel system treatments to engine flush and cooling system flush. We use it at work and its great stuff.
Previous Topic:Stripped thread
Next Topic:my crank
Current Time: Sun Nov 22 06:45:24 UTC 2026
Total time taken to generate the page: 0.0043489933013916 seconds
