Toymods » Tech & Conversions » 18R perforfance
dale30
Casino NSW
18R perforfance Sun, 13 November 2005 11:33 Go to next message
Hi Everyone
My daughter races an XT130 speedway car with an 18R in it.
Rules say stock motor with extractors and carby rejetting.
I think we have an early 18R but not sure. It has spring tensioner that screws in from the outside of the head on top timing chain, not the internal tensioner that sits between the chain.
Is the 18RC a better thing to start with.
What makes the RC lower in comprwssion.
Is there a mixture of bits from both motors that will help with a few more horsepower.
My manual says that the 18R is 113HP and the 18RC 97HP.
Is this because of lower comp or valve timing for smog control..
Any help would be great.
crostek
Oyster bay NSW
Re: 18R perforfance Sun, 13 November 2005 12:14 Go to previous messageGo to next message
dale30 wrote on Sun, 13 November 2005 22:33
Pitty much YES,
From memory (havn't played with this motor for awhile) the comp is lowered by the type of pistons and the size of the combustion chamber in the head. Have a look at the rules and see is you can use 18RG twin cam??
If you can rebuild the motor one thing I use to do was put VW forged 89mm pistons (1640cc VW set) or 90.5mm pistons and offset grind the crank to give shorter stroke, you will wind up with 1998CC or there about,(there are other combinations of cranks that will swap in just not shore mite be 22R) and it can be revved harder, up the valve size by changing the seats and valves put a good set of valve springs in and have the motor balanced.
If you can afford it get an good crank and have it counter weighted, Stan Pobjoy racing from Coffs did me one and the motor revs a lot smoother all the way to 9000.
[Updated on: Sun, 13 November 2005 21:25]
dale30
Casino NSW
Re: 18R perforfance Sun, 13 November 2005 12:31 Go to previous messageGo to next message
Unfortunatly rules dont allow any of that..bugger
Re: 18R perforfance Sun, 13 November 2005 13:25 Go to previous messageGo to next message
the 18RC's reduced performance certainly came (in part) from:
-smog equipment (air pump, EGR)
-compression
-ignition timing
-disabled carbi
am not sure whether the cam changed - i had mine reground to suit the turbo. only way would be to compare casting marks on early/late model cams.
i dont think the head changed much with the introuction of smog equipment. (note: 18RG pistons will not fit).
the external upper-chain tensioner is the one to get (older, but better)
would suggest:
-largish extractors (long primarys will help to a point)
-aggressive ignition timing (if you can keep fuel up to it)
-bigger spark (bigger ocil? a jaycar/DSE CDI unit would be good. or just the electronic spark from an 18RG)
-CAI (clean, cool air instead of engine bay heat
-remote oil-cooler (ford sandwich plate fits but you will need a shorter filter to prevent hitting the dizzi
-proper balance when rebuilding
-open up exhaust ports to suit extractors
chees, charles.
dale30
Casino NSW
Re: 18R perforfance Sun, 13 November 2005 13:43 Go to previous messageGo to next message
Thanks for that Charles..
Do the RC heads have a bigger chamber to lower comp or is it in the pistons.?
Mr DOHC
Re: 18R perforfance Mon, 14 November 2005 06:56 Go to previous messageGo to next message
the 18RC have a smalle chamber but flat top pistons, and 18RG has a hemi head and dome tops
dingaling
tas
Re: 18R perforfance Mon, 14 November 2005 08:50 Go to previous messageGo to next message
I picked up an 18-RU engine about 10 years, before i knew shit about toyota's. But this engine whent like stink! felt about twice as powerful as my previous 18-r and much much faster then friends 18-rc. Must of been worked, wish i knew.
Anyhow some guy ended up taking it off my hands and fucked it in no time, running leaded fuel in it when it was supposed to take unleaded. I didn't want to sell it, i dunno why i let that happen was a sweet piece of work that engine.
Re: 18R perforfance Mon, 14 November 2005 09:37 Go to previous messageGo to next message
dale30 wrote on Sun, 13 November 2005 23:43
the 18R and 18RC have the same piston so any compression change is in the head.
there is a bit of excess meat in the combustion chamber as the head in my 18R-turbo was opened up to 7.4:1 .
dale30
Casino NSW
Re: 18R perforfance Tue, 15 November 2005 08:55 Go to previous messageGo to next message
aNYONE KNOW WHAT THE COMPRESSION RATIOS OF 18r AND 18rc ARE.???
Bloody caps locks.!!!
jeffro RA28
Tamworth
Re: 18R perforfance Tue, 15 November 2005 09:18 Go to previous messageGo to next message
dingaling wrote on Mon, 14 November 2005 19:50
How does leaded fuel fuck them? may i ask?
Re: 18R perforfance Tue, 15 November 2005 10:21 Go to previous messageGo to next message
this <http://www.geocities.com/MotorCity/Pit/9975/dataBy Subject/GasolineEngines.html#R-series> suggests they're all 8.5:1 ... tho i thought they reduced the comp with the extra emissions stuff - i musta been wrong.
o_man_ra23
Townsville North Qld
icon10.gif  Re: 18R perforfance Wed, 16 November 2005 06:12 Go to previous message
surely you can stick a stock 18RG in. They go like stink with standard carbs, compression, cams etc. I suggest this cause i noticed you were racing an XT130, which never came with an R motor, rather a 1X series commodore crossfire motor. So if you are allowed to change to an 18R, surely you can use an 18RG. Toyota suggests 146hp for the 88230 headed motor with cast exhaust manifold and restrictive airbox. Add intake bellmouths, foam sock air cleaners and extractors, and you have a recipe for a motor which will run all day every day at high rpm, and produce funtastic power. As for electronic ignition, take the guts from a 21RC/22R dizzy, as well as the coil and ignitor from same. Ive heard about these motors being used for speedway cars before and running flat at 7000rpm all night every night without failure.
[Updated on: Wed, 16 November 2005 06:13]
Previous Topic:Starting problem with GT4 turbo engine
Next Topic:newby question - most likly asked 1000 times but here goes
Current Time: Wed Oct 14 09:49:56 UTC 2026
Total time taken to generate the page: 0.053535938262939 seconds
