Toymods » Tech & Conversions » is AE92 sx fuel pump suitable for 4AGZE?????
levin_sx
is AE92 sx fuel pump suitable for 4AGZE????? Mon, 14 November 2005 08:34 Go to next message
hey i am going to transplanting map GZE into my AE92 sx seca.
just wondering since the injectors are of larger capacity will i need to beef up my fuel supply with a bigger fuel pump??
if so i hav heard that the MA70 supra pump is a suitable fit?
main thing i need to no though is should i change it!!!
thanks guys.......... Cool Cool
[Updated on: Mon, 14 November 2005 08:35]
Re: is AE92 sx fuel pump suitable for 4AGZE????? Tue, 15 November 2005 02:27 Go to previous messageGo to next message
the standard pump is fine.
bmgtz
perth.......southside
July 2005
Re: is AE92 sx fuel pump suitable for 4AGZE????? Tue, 15 November 2005 13:18 Go to previous messageGo to next message
Ive used an ma70 pump before.......was told it had a higher capacity. easy to fit to goes into the same mounts
rallyrolla
November 2005
Re: is AE92 sx fuel pump suitable for 4AGZE????? Wed, 16 November 2005 01:35 Go to previous messageGo to next message
I have run my 20v silver top with a ae112 fuel pump and a 1jz supra fuel pump. It will run fine on both, but I suspect the ae112 pump has less pressure. Onthe supra pump the engine starts easier has a noticeable kick on the varible valves and gets much more wheelspin. Also get an efi fuel tank. Otherwise with less than a quarter tank of fuel you will starve the motor under heavy braking and conering.
Re: is AE92 sx fuel pump suitable for 4AGZE????? Thu, 17 November 2005 12:34 Go to previous message
Errr, if the pump is adequate, it shouldn't make any difference to to performance... It's only when the pump can't cope that it'll run out of fuel under higer load. The pressure is controlled by the reg, not the pump...
Previous Topic:corolla AE92 conversion
Next Topic:fixed or full floating rotors???
Current Time: Sat Oct 17 20:28:03 UTC 2026
Total time taken to generate the page: 0.0043570995330811 seconds
