Toymods » Tech & Conversions » Air Con Question
Initial_D
February 2005
Air Con Question Mon, 14 November 2005 21:55 Go to next message
I need to air compressor for a ae86. I had a guy here tell me that if you aren't carefull and you open it and air gets in, it's stuff. Is this true? All I want to do is buy another compressor and switch them over?
BradW
Bottom of the hill, Sydney
Re: Air Con Question Tue, 15 November 2005 08:58 Go to previous message
Does your A/C still have gas in it?
If so you will need to have it degassed as it is illegal to dump the gas.
Why are you changing the compressor? Is it noisy or seized?
If it is noisy or seized then the system should be flushed otherwise there could be bits of metal floating around in the system from the old compressor that could damage the new compressor or cause other problems.
The receiver/drier (filter) should also be replaced as should the o rings on any fittings that are undone.
After all this is done the system will need to be regassed and then you can drive around as cool as a cucumber again Very Happy .
Previous Topic:soarer air con re-gas
Next Topic:gen 3 3sge zorst ports.......
Current Time: Wed Oct 14 03:49:08 UTC 2026
Total time taken to generate the page: 0.061761856079102 seconds
