Toymods » Tech & Conversions » info on a 4a-ge into a TA22
Stretch
Sydney,Hurstville
info on a 4a-ge into a TA22 Tue, 15 November 2005 07:25 Go to next message
i did the search function but only found a few mild bits of info on the conversion. i would like to know exactly what is needed to put a 4a-ge into a ta22.
like what fuel system will be needed
what diff and tailshaft to suit a t-50 jdm
what mods to crossmember and gearbox cross member
any holes to be cut in the floor for the shifter?
everything...
any info would be great.
Henn
Rosanna, Melb
Re: info on a 4a-ge into a TA22 Tue, 15 November 2005 07:29 Go to previous messageGo to next message
Articles are your friend
Fuel system is same as any carby->EFI conversion
Hen
Stretch
Sydney,Hurstville
Re: info on a 4a-ge into a TA22 Tue, 15 November 2005 10:04 Go to previous messageGo to next message
anyone else got any info?
Stretch
Sydney,Hurstville
Re: info on a 4a-ge into a TA22 Thu, 24 November 2005 10:32 Go to previous messageGo to next message
im trying to find out who does the alterations to the ta22 crossmember to suit the 4a-ge engine that i have. could someone either point me into the right direction or sell me theirs. lol. seriously i need one as i am a hopeless welder. Embarassed
Dale_ta22
Forster NSW
Re: info on a 4a-ge into a TA22 Thu, 24 November 2005 11:46 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=21721&start=0&rid=7462&S=b47d424b82a 3cb5ce378e27c4fdac7cf
Towards the bottom of that thread might be of some help to you.. he's used the standard 2t crossmember, with custom mounts that take ford cortina pads (rubber bits for the mounts). There's something in there about getting copies of the mounts made up, or giving away the measurements for them.
Grega
melbourne.victoria.austra...
Re: info on a 4a-ge into a TA22 Thu, 24 November 2005 23:02 Go to previous message
yeah my message read about like this :
the drivers side one uses the std 2t mount with the flange facing the block cut off.
it measures 101mm from the face of the flange on the block at the top and 70mm from the face of the flange on the block at the bottom
that should give you the angle you need. actually if you cut n shut the std 2T one to those lengths including the face plate you should be on a winner.
the passenger side used a ae86 mount modified.
at the top its 115mm from the flange to the top
at the bottom its 60mm from the flange to the bottom
the right hand or the starter motor side of the mount had to be shimmed out 4mm to make it sit right
i used 35mm ford cortina pads as mounts. circular pads with a bolt straight thru them basically.
Previous Topic:18RG Oil Pump Shaft and flow rates
Next Topic:jaycar EBC
Current Time: Wed Nov 18 17:02:05 UTC 2026
Total time taken to generate the page: 0.01685094833374 seconds
