Toymods » Tech & Conversions » 18rg head removal
dazz
November 2005
18rg head removal Tue, 15 November 2005 09:28 Go to next message
Need to remove head from my 18rg RA40 to machine inlet side (corrosion pitting)inlet manifold won't seal! I believe they can be a bit tricky to install correctly. Cannot get a workshop manual. any idea's.
Also has anyone done a 1piece tail shaft conversion on a RA40 , don't like the cnt bearing for rally use!
people100
Rocklea qld
Re: 18rg head removal Tue, 15 November 2005 09:30 Go to previous messageGo to next message
theres not really any secrets apart from dont drop the little pin out of the cams into the front of the engine. probably easier to remove the head with the manifolds still on it. just remove the cams sprokets and pull it all out in one go.
dazz
November 2005
Re: 18rg head removal Tue, 15 November 2005 09:37 Go to previous messageGo to next message
I will need to strip the head to get machined. isn't there lash spacer etc, that need to be set up etc when re-installing.
leso
ippy
October 2005
Re: 18rg head removal Tue, 15 November 2005 10:36 Go to previous messageGo to next message
Dazz...18r engine manual on ebay...covers the 18rgu as well
cheers Les http://cgi.ebay.com.au/GENUINE-TOYOTA-18R-ENGINE-R EPAIR-MANUAL_W0QQitemZ4588697930QQcategoryZ102572Q QrdZ1QQcmdZViewItem
Mr DOHC
Re: 18rg head removal Tue, 15 November 2005 10:59 Go to previous messageGo to next message
if u need help
contact me on msn
phil8888@hehe.com
o_man_ra23
Townsville North Qld
icon10.gif  Re: 18rg head removal Wed, 16 November 2005 00:46 Go to previous message
Its as simple as People sez... cept i always remove the extractors first. There is no mention of a lash spacer in my 18RG manual... and ive read this thing cover to cover at least a dozen times, and have removed 18RG heads more than half a dozen. Just dont lose any of the bits at the end of the camshafts while your doing it, otherwise itll be time to remove the sump.
Previous Topic:Project Decade Saga Continues
Next Topic:Sourcing out 4age 256 Degree Cams?
Current Time: Sun Oct 18 23:01:57 UTC 2026
Total time taken to generate the page: 0.0054140090942383 seconds
