Toymods » Tech & Conversions » specs for 1G-GTE or 1G-GZE pistons & rods wanted
kmw777
adelaide
November 2005
specs for 1G-GTE or 1G-GZE pistons & rods wanted Tue, 15 November 2005 13:57 Go to next message
Hi, As the title says... can anybody give me the above specs for the piston ( 75mm ) and rod.
ie, pin diam, comp ht( distance from pin ctr to top of piston ), rod length, rod width and big end diam.
Thanks for any feedback, Kevin.
badboybubby
On Probation
Re: specs for 1G-GTE or 1G-GZE pistons & rods wanted Wed, 16 November 2005 10:18 Go to previous messageGo to next message
Are u doing a rebuild ? mines appart atm I'll see what I can come up with Smile
kmw777
adelaide
November 2005
Re: specs for 1G-GTE or 1G-GZE pistons & rods wanted Wed, 16 November 2005 12:57 Go to previous messageGo to next message
I found a reference on the web that said the 1G pistons and rods may fit into a toyota 4K 1300... the bore is the same at 75mm, and the stroke is only 2mm longer at 75mm, and the cylinder volume is almost the same.... so it may be close.
I run a supercharged 4K (at 15 lbs boost) in a clubman car and the standard pistons skirts crack etc.
If you can please measure the pin diam. (probably around 18,19,or 20mm) , the height from the pin centre to the top of the piston (probably around 34 to 37mm), the bigend diam. and the length of the rod centre to centre.
Thanks for your help mate,
regards, Kevin.
kmw777
adelaide
November 2005
Re: specs for 1G-GTE or 1G-GZE pistons & rods wanted Tue, 22 November 2005 12:12 Go to previous message
anybody has the comp height???
Previous Topic:Diff ratio question...
Next Topic:4AGZE IN SPRINTER tech article ATT MODS
Current Time: Sat Oct 17 21:46:59 UTC 2026
Total time taken to generate the page: 0.019062042236328 seconds
