Toymods » Tech & Conversions » 20valve to gze ignition swap
Lamphant
September 2005
20valve to gze ignition swap Tue, 15 November 2005 17:15 Go to next message
hi there guys/gals, i was reading on the net recently about the differences between the gze and 4age ignition systems, pertaining to a 4age 20vavle rwd conversion.
i was wondering if the ignition system from the gze engine can be used on the 20valve engine, to eliminate the use of the distributor and thus not having to cut or push back the firewall.
can this setup work on a FWD 20valve as well?
domasik
Re: 20valve to gze ignition swap Tue, 15 November 2005 23:03 Go to previous messageGo to next message
remove the dizzy cap and rotator button. leave the internals of the dizzy there so the computer can indetify crank angle. use 4AGZE coil packs.
are you planning to use aftermarket standalone ECU like a microtech?
if not im pretty sure u need a DLI convertor if your using the standard ECU and theyre not easy to come by either.
Lamphant
September 2005
Re: 20valve to gze ignition swap Wed, 16 November 2005 04:37 Go to previous messageGo to next message
so my best bet would be to use an aftermarket ecu rather than the standard ecu, and what is a DLI (distributor less ignition Confused )
would an aftermarket ignition system (MSD) work with this set-up properly
spoon
Sydney NSW
June 2005
Re: 20valve to gze ignition swap Fri, 25 November 2005 02:15 Go to previous message
you can get the DLI kit from meridian mototorsport, m-msport.com.au, $330, plus the water pipe relocation kits for $215. good quality stuff - im pretty happy with mine - although its still not hooked up!
Previous Topic:Help needed! corona mkII light problems
Next Topic:2JZ INTO MZ20
Current Time: Wed Nov 18 11:08:20 UTC 2026
Total time taken to generate the page: 0.0049118995666504 seconds
