Toymods » Tech & Conversions » transmission to suit 1jzgte?
1jzgteRA65
icon5.gif  transmission to suit 1jzgte? Thu, 16 January 2003 01:06 Go to next message
Hi all,
feel mildly dumb for asking this *tried a search but got nothing*
what manual trans would suit the 1j - and *hopefully* will fit in a ra23 without tooooo much modification?
Planning on running around 15psi boost so I was thinking I'd use the one from a jza70 supra? any thoughts??
Cheers all....
Remedy
Southern Sydney
Re: transmission to suit 1jzgte? Thu, 16 January 2003 01:28 Go to previous messageGo to next message
The Jza70 supra and jzz30 soarer both use a R154 5 speed. The soarer version is slightly longer I believe.
They are an extremely tough gearbox but are very large. I doubt it will fit in your Trans tunnel without some serious modification.
Re: transmission to suit 1jzgte? Thu, 16 January 2003 01:54 Go to previous messageGo to next message
A W58 transmission from a non-turbo 1JZ-GE or 2JZ-GE will bolt up to a 1JZ-GTE, and it will fit nicely in an RA23 transmission tunnel. You will probably have to modify the shifter to bring it further forward, but apart from that it should be a pretty easy job. I had to do the same thing when I put a 2JZ-GE W58 in my MA61.
All 1JZ-GTE's came with an R154 from the factory, and as mentioned above they are very large transmissions - there's no way it will fit in an RA23 without extensive modifications to the transmission tunnel.
rob_RA40
c'town, NSW
Re: transmission to suit 1jzgte? Thu, 16 January 2003 01:56 Go to previous messageGo to next message
if u want to use a R154 in a RA23 you will have to make trans tunnel modifications, ie cut it out an weld in a bigger one.
otherwise a W58 from the back of a 2JZ-GE will fit in with no trans tunnel mods and the bellhousing will be correct as well.
rob_RA40
c'town, NSW
Re: transmission to suit 1jzgte? Thu, 16 January 2003 01:57 Go to previous messageGo to next message
bloody hell norbie u beat me Mad
ahh well disregard.... Laughing
1jzgteRA65
Re: transmission to suit 1jzgte? Thu, 16 January 2003 02:13 Go to previous messageGo to next message
Cheers all for the replies Smile
Now I gotta go source a w58 :> *or at least cost them*
just one more small q? will the w58 hold 15psi ?? is that one of the tough as nails boxes that usually end up behind v8's??
Re: transmission to suit 1jzgte? Thu, 16 January 2003 03:06 Go to previous messageGo to next message
The W58 is generically referred to as the "Supra 5-speed", and yes it's often used behind V8's. 15psi shouldn't be a problem for it in a light car like the RA23, as long as you don't abuse it too much. A friend of mine has one in an MA70 turbo which is running ~11psi, ie more torque than a 1JZ on 15psi and heaps more weight to haul around, and it seems to be holding up fine!
Ollygt
Re: transmission to suit 1jzgte? Thu, 16 January 2003 08:35 Go to previous message
If you're worried about stripping your gears, you can always get the ratios strengthened and have metal straps put around the box to hold it together Wink (honest, dad did that back in his wild and leadfoot days)
Previous Topic:4AC overheating
Next Topic:MA70 starter wire
Current Time: Sat Nov 21 03:26:52 UTC 2026
Total time taken to generate the page: 0.0085909366607666 seconds
