Toymods » Tech & Conversions » what is the correct way to remove/install AE86 front anti-roll/sway bar
shinybluesteel
melbourne
what is the correct way to remove/install AE86 front anti-roll/sway bar Wed, 16 November 2005 09:45 Go to next message
Whichever term you prefer...
I gave chad a hand removing the front swaybar from his car before i bought it, we got it out by:
removing the bar-control arm links
unbolting the caster/radius rod brackets from the chassis
undoing the adjusting nuts of the caster/radius rods
manhandling, yanking, twisting and swearing and yelling at the swaybar until it came out.
what is the right way to do this? i'd ratehr leave my caster adjustment alone for now, dont mind unbolting more stuff if it will make it easier.
i'm thinking the way to go would be to unbolt the radius rods from the lower control arm, unbolt the radius rod brackets, then drop the whole thing, swap bars over then bolt back in.
sound good?
EDIT:
never mind, its in the manual, but i needed this pointed out to me by someone else.
[Updated on: Wed, 16 November 2005 12:09]
bbq_chickenwing
Re: what is the correct way to remove/install AE86 front anti-roll/sway bar Thu, 17 November 2005 23:35 Go to previous message
I just pulled mine out as a whole. I can imagine pulling out the sway bar with the support brackets on being quite hard. Sandblast and remove that rust from support bracket while you are their Smile
easy way imo - no swearing/cursing involved.
[Updated on: Thu, 17 November 2005 23:37]
Previous Topic:dyno help
Next Topic:ae86 front strut help
Current Time: Sun Oct 18 17:55:15 UTC 2026
Total time taken to generate the page: 0.067141056060791 seconds
