Toymods » Tech & Conversions » Quad throttle body adapter plate
drift_rolla
September 2005
Quad throttle body adapter plate Wed, 16 November 2005 09:46 Go to next message
does any body know where i could get my hands on an adapter plate to fit 20v quad throttle bodies on a 4age.
[Updated on: Wed, 16 November 2005 09:53]
shinybluesteel
melbourne
Re: Quad throttle body adapter plate Wed, 16 November 2005 09:48 Go to previous messageGo to next message
to what?
Big T
Re: Quad throttle body adapter plate Wed, 16 November 2005 09:57 Go to previous messageGo to next message
To his ass so he can make the most of turbulent airflow down there Laughing Laughing Laughing
I assume he means a 16v 4ag so look up T3. They're available off the shelf.
Eddie.
drift_rolla
September 2005
Re: Quad throttle body adapter plate Wed, 16 November 2005 10:11 Go to previous messageGo to next message
what do you mean T3
isn't a T3 a turbo?
Big T
Re: Quad throttle body adapter plate Wed, 16 November 2005 10:40 Go to previous messageGo to next message
Yeah it is as well but i was refering to Techno Toy Tuning.
xolent
Re: Quad throttle body adapter plate Wed, 16 November 2005 11:11 Go to previous messageGo to next message
technotoytuning.com
ae86drift
sydney.au
Re: Quad throttle body adapter plate Wed, 16 November 2005 13:17 Go to previous messageGo to next message
i recv'd mine today
sooo fuckin hot
Windex
Melburn!
June 2005
Re: Quad throttle body adapter plate Wed, 16 November 2005 21:09 Go to previous messageGo to next message
Anybody know if anyone does them for the 3sge?
shinybluesteel
melbourne
Re: Quad throttle body adapter plate Thu, 17 November 2005 07:44 Go to previous messageGo to next message
yes
Windex
Melburn!
June 2005
Re: Quad throttle body adapter plate Thu, 17 November 2005 12:36 Go to previous messageGo to next message
Care to elaborate?
old_mr2
Re: Quad throttle body adapter plate Thu, 17 November 2005 18:02 Go to previous messageGo to next message
I had a look at the site and it does not look like they sell one for 3sge
ae86drift
sydney.au
Re: Quad throttle body adapter plate Fri, 18 November 2005 01:50 Go to previous messageGo to next message
no t3 do not sell one. pretyt mech old corollas/starlet stuff only from those fellas.
i haven't seen any 3sg adaptor plates through my searches, maybe try getting one fabricated and organise a group buy for them? Smile
takai
Re: Quad throttle body adapter plate Fri, 18 November 2005 02:19 Go to previous messageGo to next message
Trd make them
Windex
Melburn!
June 2005
Re: Quad throttle body adapter plate Fri, 18 November 2005 07:02 Go to previous messageGo to next message
And this is an easy one... where do you get TRD products from?
shinybluesteel
melbourne
Re: Quad throttle body adapter plate Fri, 18 November 2005 07:05 Go to previous messageGo to next message
TRD
Big T
Re: Quad throttle body adapter plate Fri, 18 November 2005 09:24 Go to previous messageGo to next message
^^^^ Laughing Laughing Laughing Laughing
drift86levin
brisvegas
Re: Quad throttle body adapter plate Fri, 18 November 2005 13:01 Go to previous messageGo to next message
here is mine i got..the suite the silver top 20V quads, they come with a 3mm fitting in each port, i tapped another 3/8 fitting there too..t piece together your 3mm ones for a good stable map sensor line, and the 3/8 ones for your brake booster line..by having the larger 3/8 one linking all of them together it also acts like a balance tube, and will make it idle a bit smoother..
Matty
http://images.cainer.net//uploads/n2.jpg
http://images.cainer.net//uploads/n3.jpg
[Updated on: Fri, 18 November 2005 13:02]
ae86drift
sydney.au
Re: Quad throttle body adapter plate Fri, 18 November 2005 13:36 Go to previous messageGo to next message
mat could you take some closer pictures of your setup for us?
can you get a decent vacumn reading from that setup?
cheers mate! Smile
Re: Quad throttle body adapter plate Fri, 18 November 2005 20:05 Go to previous messageGo to next message
internal pics of the adaptor would be appreciated Wink how nice are the transitions?
oh and btw, what do quad throttle go for these days... in oz....
3000-5000 yen seems cheap to me?
as for MAP signal, a restrictor int he line from the quads, combined with a fuel filter sized cavity (i used a carby fuel filter Wink ) will work wonders on the MAP signal, and doesn't slow it down enough to notice.. think of it as a resistor and capacitor for air....
when the MS guys did testing, they had about 8 or 10 metres of vac line between car and ECU and it made buggerall difference (ie, in a good way)..
ae86drift
sydney.au
Re: Quad throttle body adapter plate Fri, 18 November 2005 23:46 Go to previous messageGo to next message
the adapter has pretty good ports and seems nice enough.
the t3 adaptor is $200USD
the normal way most of the ae86 guys get a map signal is running 4 vac lines from the runners on the manifold into a distribution chamber (your cavity) where there it is also met with brake booster vacumn lines etc and then a single runner to the map sensor
care to draw a picture of your setup? Smile its something iver gotta construct soon and if your setup works well then ill use that!
this is assuming quads to air right? not using an intake chamber of any sort
but ive never heard of a restrictor in line to the sensor? i guess it would add to the vacumn right?
who are these MS guys?
[Updated on: Fri, 18 November 2005 23:47]
xolent
Re: Quad throttle body adapter plate Sat, 19 November 2005 00:50 Go to previous messageGo to next message
megasquirt?
Re: Quad throttle body adapter plate Sat, 19 November 2005 01:29 Go to previous messageGo to next message
ahh i meant how much do the actual quad throtles go for.. i was thinking of picking a few up Wink
as for the restrictor thing... ppl do it different ways..
the idea of the restrictor is to reduce the amount of air that is pulled during each "suck", and also reduce the backflow when the cylinder is not sucking.. it basically just reduces the amplitude of vacuum change.
a very easy way to make a restrictor is to get MIG welding tips... ppl use maybe 0.8 to 1.2mm tips (ie hole size) and the outside is maybe.. 4-5mm diameter? so it can be slipped inline with nirmal vacuum tube Razz
some people run a restrictor between each runner and the chamber. others connect all the ports together and then put the restrictor after the join, so there is only a single restrictor.... i don't know which is best.
some peple also run the restrictor _after_ the chamber...
for me i just had high overlap cam, and the take off point was on the plenum (no quads) so i didn't have a choice.. i just ran 1.2mm restrictor and a Ryco carby fuel filter (which got strange looks as it was incabin Razz )
so basically... you can experiment.. it helps to have realtime datalogging capability on your ECU so you can see changes in the MAP quality. a pack of MIG welding "contact tips" is like $5 for 5 or something, bloody cheap... get maybe 0.8 or 0.9 as a start.. you can always cut them in half and drill out to larger size later...
at first try with lines connected and no chamber...
then with chamber
then with restrictor before chamber
then with restrictor in each line before joining
you can graph what is likely to happen.... each suck is a negative pulse that is kinda sinusoidal for as long as i lasts (which at idle is basically the time the piston is going down, ie 180 crank degrees, or 1/4 of engine cycle)
yar, Megasquirt.. a wealth of EFI info for anyone who wants to learn Wink
Re: Quad throttle body adapter plate Sat, 19 November 2005 01:32 Go to previous messageGo to next message
oh, and what does a set of quads weigh... for postage...
shinybluesteel
melbourne
Re: Quad throttle body adapter plate Sat, 19 November 2005 02:30 Go to previous messageGo to next message
old corrolas, a set of quads usually goes for about 350 bucks.
if you feel like picking up a set (or other bits) in teh japans, PM me.
Re: Quad throttle body adapter plate Sat, 19 November 2005 05:40 Go to previous messageGo to next message
shinybluesteel wrote on Sat, 19 November 2005 13:30
shit eh.... i doubt anyone on toymods would pay that much tho Razz
have a quick squiz at:
http://page.auctions.yahoo.co.jp/jp/auction/809498 38
and
http://page11.auctions.yahoo.co.jp/jp/auction/n293 42030
i was just looking for some for the screwed project Razz
how much do they weigh? postage aint cheap Sad
takai
Re: Quad throttle body adapter plate Sat, 19 November 2005 06:48 Go to previous messageGo to next message
The actual throttles are about 1-1.5kg, not much at all. Just ditch the manifold and plenum over in Japan. Smile Ill take a pic of the runners on the T3 units before and after i shape them today too.
Re: Quad throttle body adapter plate Sat, 19 November 2005 07:03 Go to previous messageGo to next message
takai wrote on Sat, 19 November 2005 17:48
ahh sweet Very Happy 2-3kg will be well under a hundred bucks shipping...
thanks Takai, looking forward to pics.
heh heh, i can't imagine the stock plenum will take that much boost.. or would it??
hmmmmmmmmm Wink
so what should i make sure i get? ie any specific linkages, AE101, AE111???
apologies for threadjack Wink i'd love to see a set of these on a K mmotor tho Razz
SR20 trueno
July 2005
Re: Quad throttle body adapter plate Sun, 20 November 2005 01:57 Go to previous messageGo to next message
visionr.com.au
Kai Power Japan 4 throttle connection kit with 70mm funnels for ae8616v - $1350 delivered
b1gb3n
south Melbourne/KL
Re: Quad throttle body adapter plate Sun, 20 November 2005 18:29 Go to previous messageGo to next message
Shocked
a complete 20v motor, is about $900??
quads cost 1/3 of the engine??
ae86drift
sydney.au
Re: Quad throttle body adapter plate Sun, 20 November 2005 21:48 Go to previous messageGo to next message
yeah.. people ask way too much for them...
i got mine for $190
Re: Quad throttle body adapter plate Mon, 21 November 2005 00:39 Go to previous messageGo to next message
bah, not even worth the effort of posting then Wink
ae86drift
sydney.au
Re: Quad throttle body adapter plate Mon, 21 November 2005 01:09 Go to previous messageGo to next message
...after i shape them today too.
are you fitting them to bigporthead or ae111 throttles or something?
takai
Re: Quad throttle body adapter plate Mon, 21 November 2005 01:52 Go to previous messageGo to next message
Nope, fitting to smallport as usual.
Just the hard edges in the plenum are crap, really need going over with a die grinder, but i have no compressed air atm and the dremel doesnt have a collet large enough.
Ive just cleaned up the edges for now, but will really take to it with the die grinder when i next take them off.
ae86drift
sydney.au
Re: Quad throttle body adapter plate Mon, 21 November 2005 06:25 Go to previous messageGo to next message
yeah, there is quite a large ridge inside the runners i was concerned about
i might have to smooth mine out also... :s bugger
drift86levin
brisvegas
Re: Quad throttle body adapter plate Mon, 21 November 2005 12:28 Go to previous messageGo to next message
i found the T3 manifold looked quite sexy, and all i did was smooth with some sand paper the tapped thread where it burred into the port..i also had to open up the face of the port on the head to make sure that it didn't have a step-in, the T3 manifold is a little bigger than the standard smallport..port.. Smile i dunno how well it will idle..no body seemed to awnser when i asked the question on a few seperate occasions, so i thought fuck it, i'll just do it and find out the hard way..
takai
Re: Quad throttle body adapter plate Mon, 21 November 2005 21:20 Go to previous messageGo to next message
Idles quite well.... with 308* cams. Evil or Very Mad
ae86drift
sydney.au
Re: Quad throttle body adapter plate Mon, 21 November 2005 21:51 Go to previous message
what setup do you run takai?
ecu?
an intake manifold?
sensors?
Previous Topic:4AGE squeel noise
Next Topic:What type of turbo is this *pics*
Current Time: Sat Nov 21 04:07:51 UTC 2026
Total time taken to generate the page: 0.0090341567993164 seconds
