Toymods » Tech & Conversions » an AW11 question
old_mr2
an AW11 question Thu, 06 June 2002 17:31 Go to next message
Guys
I own a 1987 NA AW11
I just relocated the Air Flow Meter to sit next to the TVIS. And wacked a 5" UNI pod filter on the other side.
Heres what happened: It sounds great, really deep and throaty.
When the TVIS kicks in its great, nice and torquey. However when the revs are low it seems like it is missing and that it is struggling through the low rev range. Is there any thing I can do to combat this?
Thanks, any info is much appreciated. No No No
Ben Wilson
Re: an AW11 question Thu, 06 June 2002 22:08 Go to previous messageGo to next message
I found with my old NA motor that if I mounted the AFM so it was tight to the manifold that it wouldn't run right at low revs. I think the shaking of the motor was moving the vane in the AFM. I fitted a rubber hose about 10cm long between them and bolted the AFM to the rear firewall and it ran fine.
old_mr2
Re: an AW11 question Fri, 14 June 2002 08:59 Go to previous messageGo to next message
Thanks Ben,
that sounds like a nice tip. But if I insert the 10cm there will be no room for the pod filter as it will run into the left side of the engine bay. Just wondering if you ran into this problem. And what did you do to get around it.
Yawn
Ben Wilson
Re: an AW11 question Fri, 14 June 2002 14:11 Go to previous message
Mine just scraped in - The hose might have been a little shorter than 10cm, it just needed to have a bit of give in it. I just bought a pipe coupling from a hardware shop.
Previous Topic:AFM 4AG idle problem (long)
Next Topic:K&N Air Filters
Current Time: Tue Oct 13 15:30:42 UTC 2026
Total time taken to generate the page: 0.022156000137329 seconds
