Toymods » Tech & Conversions » LSD Conversion
masTers
icon5.gif  LSD Conversion Thu, 16 January 2003 05:00 Go to next message
Will the LSD from a AE82 Seca fit/bolt right into an AE82 Twincam rolla?
Steve
MR. 2
Parramatta
Re: LSD Conversion Thu, 16 January 2003 06:03 Go to previous messageGo to next message
if they are both 4a blocks they sure will champ
masTers
Re: LSD Conversion Thu, 16 January 2003 14:58 Go to previous messageGo to next message
Awesome, how much is one roughly in Aust Dollars?
Steve
MR. 2
Parramatta
Re: LSD Conversion Thu, 16 January 2003 21:37 Go to previous messageGo to next message
wouldnt have a clue the only lsd that i know of in the 4a boxes was a 20v import and a 4agze.... with the ze i know u will have to change ur hubs as u will have to use bigger drive shafts but u know what they say the bigger the better.
good luck hunting see ya champ...
masTers
Re: LSD Conversion Fri, 17 January 2003 16:44 Go to previous messageGo to next message
The AE82 Seca with the 4A-E 1600 sohc came with an LSD, i was hoping this would be a straight swap into the twincam.
Steve
dahashrat
Re: LSD Conversion Sat, 18 January 2003 07:29 Go to previous messageGo to next message
ok, I gotta clear some things up for you, no ae82's came out of the factory with a LSD.
There's no such thing as a "4A-E".
The ae82's in australia came with either a 4A-C, a 1.6 SOHC, or a 4A-GE 1.6 DOHC.
The only FWD LSD equipped boxes are out of the ae92, and ae101 levin gtz's, and not all those cars are equipped with them. The LSD boxes are designated as E-51. There are also LSD equipped boxes out of the ae111 levin 6-spd (C-60), but I'm not sure if all these are LSD's also.
All these boxes can be made to fit your twin cam, but you will probably need to change the mounting points etc, and as stated abouve, hubs and driveshafts would need to be swapped for the right ones for the box.
The ratios of these boxes would not be good for a N/A car, apart from the C-60 6 speed, although these are horrendously expensive.
so yeah, there's no easy way of getting an lsd in your C-52. There are probably after market ones around, but they would most likely be very expensive, or they'd be more common.
Theres a lot of info about these boxes and what they'll go into on this and other forums, so do a search and you'll find more info then you'll need. Razz
masTers
Re: LSD Conversion Sun, 19 January 2003 04:15 Go to previous messageGo to next message
How about the SECAs? Ive been in two now. both with LSDs which both drivers claim is factory.
Steve
dahashrat
Re: LSD Conversion Sun, 19 January 2003 11:58 Go to previous messageGo to next message
No, the seca's are mechanically the same as a hatch. As I said, I can categorically state that no ae82's came from the factory with an LSD.
I've got an ae82 twin cam seca, and it definetly doesn't have one.
I think your friends are telling porkies. Why don't you jack up the front of the car and spin the wheels, if they turn different directions, it hasn't got a LSD, which is what I think will definetly happen.
85_SECA
Re: LSD Conversion Thu, 23 January 2003 15:24 Go to previous messageGo to next message
been there and done that and yea turning one wheel makes the other turn the same way
oh if the car is in gear it dont turn at all
BTW the 4a-e dose exist
spec:
http://www.superjamie.net/oldcorollas/5-2.html
http://www.toyotagtturbo.com/engines2.html
its just under the 4a-lu OR dont it happen either
85_SECA
Re: LSD Conversion Thu, 23 January 2003 15:32 Go to previous messageGo to next message
"with the ze i know u will have to change ur hubs as u will have to use bigger drive shafts but u know what they say the bigger the better."
true the larger components can be had from an aust. built 85 SECA
ha ha. what would i know. got a wrecked 88 in the shed i got for a few bucks. the drive shafts are smaller and so are the cv's but the hubs are the same Shocked
Johnny
Sydney, OZ
Re: LSD Conversion Fri, 24 January 2003 05:26 Go to previous message
First of all, There is no need to change you hub's, I have used GZE, 20V and now have a 6-spd in my rally car and I haven't had to change the hubs yet! Yes the GZE shaft is bigger, but the spline that goes into the hub isn't. Also 6-spd's all have LSD from what I have seen, the other two are available, just when your buying one chech if it is or not. To fit any of these require minor mod's... Top mount. GZE's have crap ratio's standard for N/A engines, but Holinger do have off the shelf ratio's that solves that problem.
Previous Topic:87 hilux tray back
Next Topic:1g-gte or 1jz?????
Current Time: Mon Oct 26 07:34:05 UTC 2026
Total time taken to generate the page: 0.011375904083252 seconds
