Toymods » Tech & Conversions » AE86 Charge light on
genkin
AE86 Charge light on Wed, 16 November 2005 22:51 Go to next message
Hey guys, for about a week now my 'charge' light has been going on and off while i drive. It may stay off for the first 5 mins, then turns itself on for the rest of the drive. I have put a brand new battery in a few days ago. But the problem was still happenening with the previuos battery.
This morning I went to start the car and it took a while to kick over Sad
So the battery is definately getting reduced charge.
I really don't want the alternator to be the problem Sad
What can I check??
* plugs?
* earth and other wires?
* belt tension?
* coil?
Any help appreciated (hope it starts at home time Razz)
Julz01
Re: AE86 Charge light on Wed, 16 November 2005 23:27 Go to previous messageGo to next message
Just a suggest as it has happened to me
But if you have recently installed any electrical stuff, like Cd player check all the wiring on them.
I had this problem and it was because on of the wires from the Cd player was slightly touching the body and draining the battery.
Also it could be the battery you brought as it may not be powerful enough?
genkin
Re: AE86 Charge light on Wed, 16 November 2005 23:34 Go to previous messageGo to next message
cheers for the advise Julz.
I cant think of anything I have hooked up recently. I'll have a look behind the CD player to make sure no wires have come loose.
The battery should be fine. The previous one worked fine for months, I have since moved it into another car and bought an exact replacement. The problem popped up about a week ago. I have since changed the battery two nights ago. but still same problem.
WHITCHY
Castle Hill
Re: AE86 Charge light on Wed, 16 November 2005 23:43 Go to previous messageGo to next message
This is what mine did when my alternator was rooted.
Just put a new one on. I picked a replacement up for $40, so its gonna be cheaper than if you keep replacing your battery!
Or if you wanna be sure get a multimeter and test the alternator!
Goodluck.
-Whitchy-
StockAE86
Outer Sth East burbs, VIC
Re: AE86 Charge light on Thu, 17 November 2005 00:55 Go to previous messageGo to next message
In my experience when my alternator had died the charge light was on constantly not intermitent like your problem.
Perhaps see if you can borrow an alternator off someone and try that out as yours could be on its way out.
Alternatively sounds a bit like a wiring problem being intermitent like it is
Slippy
March 2005
Re: AE86 Charge light on Thu, 17 November 2005 01:14 Go to previous messageGo to next message
My alternator died when this happened. Picked up a nice cheap new one Smile Mates work in parts :)Smile If you want my old alternator to re-bush etc PM me.
beige_bandit
September 2005
Re: AE86 Charge light on Thu, 17 November 2005 04:59 Go to previous messageGo to next message
check wiring clip on back of alternator!
Mine did this when clip was slightly loose(charge light on and off)
or the alternator is giving up the ghost Confused
Re: AE86 Charge light on Thu, 17 November 2005 08:02 Go to previous messageGo to next message
They often get like this when they're dying - sometimes if the light is on, give it a hearty slap with a shifter/tyre lever, and it might work for a few minutes. Usually indicates that the brushes are worn out.
Skaney
Re: AE86 Charge light on Thu, 17 November 2005 08:19 Go to previous message
Thats what mine did, I didnt do up the bolt tight enough and it wriggled itself loose over time. Ended up melting the wire off and I lost all power one day..
So check it out.
Previous Topic:Quad Throttles on a 100 or 86 km
Next Topic:2002 Levin performans
Current Time: Sat Nov 21 00:13:17 UTC 2026
Total time taken to generate the page: 0.0061228275299072 seconds
