Toymods » Tech & Conversions » dyno help
stealth007008
perth
June 2005
dyno help Thu, 17 November 2005 08:34 Go to next message
when it comes to dyno graphs - how come on some power runs, the afr starts off around 14-15 and drops to safe levels around 3500 revs (max boost)whereas some eg mine stays a constant 12:1 throughout the whole rev range. do u think theres a difference in fuel ecconomy between them
Re: dyno help Thu, 17 November 2005 08:39 Go to previous messageGo to next message
Was your graph after you got the S-AFC tuned?
stealth007008
perth
June 2005
Re: dyno help Thu, 17 November 2005 08:42 Go to previous messageGo to next message
yep it was initially tuned to make 270 then i got the hiflow done and put in back on the dyno and it made 305 without changing the mixtures however the midrange power is fucked - what u think?
Re: dyno help Thu, 17 November 2005 12:21 Go to previous messageGo to next message
Ideally the better controlled the AFR's are, the better the car should be. Your one is probably smoothed out more because they should've done that with the piggyback.
terra
July 2005
Re: dyno help Thu, 17 November 2005 20:29 Go to previous messageGo to next message
hiflow = loose in the bottom, gain in the top.
stealth007008
perth
June 2005
Re: dyno help Thu, 17 November 2005 23:38 Go to previous messageGo to next message
u obviously havent seen my dyno graph then i gained more everywhere particularly at bottem end
http://i30.imagethrust.com/i/73904/dyno1.jpg
http://i24.imagethrust.com/i/73916/dyno2.jpg
afdmitt theirs more boost but the stock turbo wouldnt make any more then what it did (bleed valve all th way out)
Re: dyno help Thu, 17 November 2005 23:40 Go to previous message
Hehe, my guess is it spikes around 3750rpm correct? Wink
Previous Topic:1GGTE clutch issue
Next Topic:what is the correct way to remove/install AE86 front anti-roll/sway bar
Current Time: Mon Oct 19 17:44:23 UTC 2026
Total time taken to generate the page: 0.155837059021 seconds
