Toymods » Tech & Conversions » 4age cranking RPM
johnO2
victor harbor
June 2005
4age cranking RPM Sat, 19 November 2005 02:44 Go to next message
Hey
I was wondering if some one could tell me what RMP my starter motor should be turning my engine over at. It's a 4age.
shinybluesteel
melbourne
Re: 4age cranking RPM Sat, 19 November 2005 03:28 Go to previous messageGo to next message
500?
johnO2
victor harbor
June 2005
Re: 4age cranking RPM Sat, 19 November 2005 04:28 Go to previous messageGo to next message
Ok then any idea why it's cranking at around 200-300 rpm.
I've got a big optima gel cell in the back. Around 1000 it said on it, I think.
Would my problem be my battery or my starter motor.
shinybluesteel
melbourne
Re: 4age cranking RPM Sat, 19 November 2005 04:30 Go to previous messageGo to next message
does it start?
did you put the battery in the boot recently? what gauge battery cable are you using?
johnO2
victor harbor
June 2005
Re: 4age cranking RPM Sat, 19 November 2005 04:45 Go to previous messageGo to next message
Engine has just gone in to the car. Battery cable is the highest gauge my local auto shop had. Should I give up and take it to a pro. I've being quoted 60 bucks an hour is that reasonable rate for an auto electrician?
Re: 4age cranking RPM Sat, 19 November 2005 05:00 Go to previous messageGo to next message
250-300rpm is about normal..
Re: 4age cranking RPM Sat, 19 November 2005 07:26 Go to previous messageGo to next message
Just listen to it... does it sound like it's got a bad hangover, or does it sound just fine?
TE72_Turbo
Re: 4age cranking RPM Sat, 19 November 2005 09:03 Go to previous messageGo to next message
spark plugs in or out?
Mine cranked at 250-300 with plugs, almost 500 without.
What are you trying to achieve? Does the motor not start or something?
IRA11Y
Club Member
Re: 4age cranking RPM Sun, 20 November 2005 10:06 Go to previous messageGo to next message
4A-C and 4AGE up to the 20V variants all had 200RPM starter motors, after that the 20V's all had reduction drive starters which cranked at 250RPM
as an after thought re the conversation the other night... since you have moved the battery have you made sure the earth points at the battery are grounding well and have you got a good earth line back to the engine block.
[Updated on: Sun, 20 November 2005 10:36]
berad
Re: 4age cranking RPM Sun, 20 November 2005 10:24 Go to previous message
i really doubt this is ur prblem as to why its not starting.
Previous Topic:1j\2j water pump+ pulley confirm part # please
Next Topic:308- supra bellhousing ID
Current Time: Thu Nov 19 07:56:42 UTC 2026
Total time taken to generate the page: 0.0064859390258789 seconds
