Toymods » Tech & Conversions » 4AGE squeel noise
Gleno28
4AGE squeel noise Sat, 19 November 2005 06:49 Go to next message
Hey peoples, 4AGE Noise question. MR2 4AGE been converted to RWD.
It only happens when the engine is up to temp, kinda gets intermittent squeels when it's approaching mid gauge temp.
Engine has:
new water pump
new tensioner
new throwout bearing
new clutch
no engine fan
checked alternator
no other belts
full sump
full water
Make the noise with clutch in or out in neutral, sounds louder from under the engine. A mechanic mate had a quick listen, doubts it's a bottom end bearing. Any ideas?? cam bearings??
Glen.
Re: 4AGE squeel noise Sat, 19 November 2005 07:24 Go to previous messageGo to next message
What happens if you slip the belt off and run it for a minute?
Gleno28
Re: 4AGE squeel noise Mon, 21 November 2005 06:09 Go to previous messageGo to next message
With the belt off, still get the same noise...
kewp
wollongong
Re: 4AGE squeel noise Mon, 21 November 2005 06:13 Go to previous messageGo to next message
My old bigport used to squeal when it was about to overheat, i don't know what it is, but i think its normal
Re: 4AGE squeel noise Mon, 21 November 2005 07:12 Go to previous messageGo to next message
Gleno28 wrote on Mon, 21 November 2005 17:09
so that rules out water pump, alt etc...
so it has to be either valve train, crank, oil pump, or front/rear seals.... what else is there?
Gleno28
Re: 4AGE squeel noise Mon, 21 November 2005 23:21 Go to previous message
Cool, it's got a new rear main seal, might have to go off to the mechanic for a look...
Glen.
Previous Topic:how much for 4a-lc?
Next Topic:Quad throttle body adapter plate
Current Time: Sat Nov 21 03:51:52 UTC 2026
Total time taken to generate the page: 0.0043079853057861 seconds
