Toymods » Tech & Conversions » RTA Regulations on engine modifications?
brodiepearce
Ipswich
February 2005
RTA Regulations on engine modifications? Sat, 19 November 2005 09:13 Go to next message
After looking for a while, I still haven't found anything, the question is,
Does the RTA have any regulations reguarding engine mods such as cam duration, valve lift etc.
After looking at all the 4AGEs on the forums which aftermarket cams etc. Most seemed to be around 270ish duration with about 8mm lift, though when I get round to completing my car, I'm looking at running 280 duration with 10.3 lift (with aftermarket springs, shims etc. of course), but because this is so much more than the average here, I'm guessing theres either a regulation on it, or that much lift makes the car horrible to drive on street lol.
I know there's regulations on how much extra displacement you can add, but can't find anything on the above...:S
[Updated on: Sat, 19 November 2005 09:31]
Re: RTA Regulations on engine modifications? Sat, 19 November 2005 09:35 Go to previous messageGo to next message
emissions...
if the cam sounds lumpy, then you might be asked to get an emisions check.... this could be done by a cop that pulls you over too... (or maybe just EPA?)
basically, for any car or engine which had to meet emissions requirements, you still have to meet them, which pretty much rules out any performance mods that anyone does.... Sad
mynameisrodney
Kellyville, Sydney
Re: RTA Regulations on engine modifications? Sat, 19 November 2005 09:55 Go to previous messageGo to next message
do they check this when you get a blue slip? when i register my car i plan to have a 2tg/3t hybrid with a bit of work done to it. am i better off leaving the stocko engine in there untill after i get my blue slip?
chris
havabeer
new castle
July 2005
Re: RTA Regulations on engine modifications? Sat, 19 November 2005 10:50 Go to previous messageGo to next message
so you could do a few mods like cams etc and balance it out with a good CAT (as in cut down on emission, not high flow) and other pulltion control methods. but would these pollution mods affect the peformance you trying to achieve?
how would the determin if you have changed your ECU. or does that not come into these regulations?
Re: RTA Regulations on engine modifications? Sat, 19 November 2005 11:23 Go to previous messageGo to next message
well.. unless approved specifically, aftermarket ECU's are not legal...
nor are changes to stock ECU, but it is harder to do that...
performance doesn't HAVE to increase emissions... but big cams will increase overlap = more emissions...
brodiepearce
Ipswich
February 2005
Re: RTA Regulations on engine modifications? Sun, 20 November 2005 02:03 Go to previous message
Is there any idea how high duration and lift you could go without infringing on emissions standards?
And by lumpy, I gather that means it sounds 'lumpy' when it idles?
Previous Topic:Idle, stalling and fouled spark plug problem on 7mgte
Next Topic:TRD rear springs
Current Time: Thu Nov 19 10:36:16 UTC 2026
Total time taken to generate the page: 0.0063741207122803 seconds
