Toymods » Tech & Conversions » Radiator return pipe relocation
stradlater
Arthurs Creek, Victoria
Radiator return pipe relocation Thu, 16 January 2003 22:17 Go to next message
I'm doing a 1g-gte into the ra23 as most of you know and I need to relocate the radiator return pipe on the ra23 radiator. I'm just wondering what's the best way to do it and is there a specific position it needs to be in?
Bugman
Re: Radiator return pipe relocation Sat, 18 January 2003 09:47 Go to previous messageGo to next message
seriously, if you are doing it you should try and use the ga70 radiator.. espically if your planning on runinng a big single pump 30odd psi like I think you are.
I just did the 1g conversion and I used the standard radiator shearly for speed of conversion and the car cooks in hot weather like I had today 35C and sits at half on normal days, it does ok but you cant go to hard on the turbos or it produces too much heat.
relocate the top pipe to the passanger side of the filler neck and the bottom pipe from the passanger side corner to the drivers side corner... you will see when you try and sit it all in there.
stradlater
Re: Radiator return pipe relocation Sun, 19 January 2003 22:02 Go to previous messageGo to next message
Well, I would use the ga70 radiator, however, a) does it fit and b) I don't have one. I thought the pipe relocations were like what you were talking about, however I dont' know how to go about relocating them, I mean how it's actually done. I'm thinking I might go and get the thing triple cored and then get them to relocate the pipes.
Bugman
Re: Radiator return pipe relocation Mon, 20 January 2003 10:43 Go to previous messageGo to next message
i got a radiator place to do it.. cost $70 from memory
CrAiGzEE
south of the big smoke
Re: Radiator return pipe relocation Mon, 20 January 2003 11:31 Go to previous messageGo to next message
ya can get around relocating it but i dont recommend it!, just cut the outlet pipe shorter
Bugman
Re: Radiator return pipe relocation Mon, 20 January 2003 11:40 Go to previous message
or push the motor soo far back that it sits between the driver and passanger and then you have heaps of room Smiley =
Previous Topic:3S trouble
Next Topic:Boring out a 1UZ-FE
Current Time: Fri Nov 20 01:44:45 UTC 2026
Total time taken to generate the page: 0.0052928924560547 seconds
