Toymods » Tech & Conversions » 3K Head Query
Trent-KE30
Tamworth NSW
icon4.gif  3K Head Query Mon, 21 November 2005 09:17 Go to next message
Hey Guys,
I noticed i had coolant slowly leaking out of my 3K somewhere i thought it could have been a welch plug behind the flywheel or exhaust but i was wrong it is coming out of the plate on the back of the head.
Now to fix this do i just throw some gasket sealant behind there or is there a proper way to fix it, was there a gasket for it?,
Any help will be appreciated,
Cheers Trent
jeffro RA28
Tamworth
Re: 3K Head Query Mon, 21 November 2005 09:49 Go to previous messageGo to next message
im not to sure of the features of the 3k head trent, but is the plate easily removable?
If so take the time to remove it, clean it up with the wire buff then use loctite or similar gasket maker or sealer and re-install.
Trent-KE30
Tamworth NSW
Re: 3K Head Query Mon, 21 November 2005 10:25 Go to previous messageGo to next message
Yes jefferson the plate is easily removed, bit of loctite you say?, might give it a shot,
Re: 3K Head Query Mon, 21 November 2005 10:29 Go to previous messageGo to next message
be bloody careful not the break the rusted bolts when you take the plate off.....
if you do, a whole bunch of epoxy and some chux superwipes will hold it for a while Wink
Trent-KE30
Tamworth NSW
Re: 3K Head Query Mon, 21 November 2005 10:32 Go to previous messageGo to next message
ahaha i always knew the britanica would reply, cheers stew
Re: 3K Head Query Mon, 21 November 2005 11:59 Go to previous messageGo to next message
Trent-KE30 wrote on Mon, 21 November 2005 21:32
meh, i had same problem once and broke a bolt.... well.. 2 of them.... so 2 bolts, some epoxy and kitchen equipment saw me thru till next head upgrade Wink
Trent-KE30
Tamworth NSW
Re: 3K Head Query Mon, 21 November 2005 20:21 Go to previous messageGo to next message
HAHAHA Laughing
Mine don't look tight Rolling Eyes i hope not
TRAV-KE55
Shepparton
Re: 3K Head Query Tue, 22 November 2005 07:30 Go to previous messageGo to next message
As said earlier be very carefully not to break the 6mm bolts, if you manage to get them out replace them regardless just because they will quiet often bust as you are doing them back up, also the real early (big port from memory) 3K cyl heads have a welch plug instead of the tin plate, that could be more tricky, wort comes to worst its not a big job to do a head gasket on a 3k anyway, and gives you a chance to clean up some ports!!!
Trav
Trent-KE30
Tamworth NSW
Re: 3K Head Query Tue, 22 November 2005 08:48 Go to previous message
Lol yeah thanks Trav i work at a engine reco shop so shouldnt be a hassle, yeah i read up somewhere about the bigports came with welch plugs.
Cheers Man
Trent
Previous Topic:"T" T50 vs "A" T50
Next Topic:3TGTE - Detonation under load
Current Time: Fri Nov 20 21:26:41 UTC 2026
Total time taken to generate the page: 0.016817092895508 seconds
