Classifieds » Engines, Accessories and other Mechanicals » FS Injectors - Possibly Smallport 4A
Toymax
Penrith
FS Injectors - Possibly Smallport 4A Mon, 21 November 2005 10:36 Go to next message
Set of four Denso injectors for sale - part no. 23250-74010.
These are ultrasonically cleaned and balanced so they all flow the same (certificate available). New O-rings and seals all round.
For those that understand them, figures are 100ml for a 20-sec timed open flow, and 68ml for a 40-sec timed pulse flow (that's 246cc in the old language, I'm lead to believe).
$200 firm.
bantech
Bathurst
Re: FS Injectors - Possibly Smallport 4A Tue, 22 November 2005 10:31 Go to previous messageGo to next message
Do you have a fuel rail to go with them?
Ta
Toymax
Penrith
Re: FS Injectors - Possibly Smallport 4A Wed, 23 November 2005 08:42 Go to previous messageGo to next message
Yes mate, got a spare one I can throw in. No extra cost.
bantech
Bathurst
Re: FS Injectors - Possibly Smallport 4A Thu, 24 November 2005 01:45 Go to previous messageGo to next message
Hmmmmm - have you had these running recently?
If so, standard or aftermarket ECU?
I'm trying to work out if they'll run on standard 100kw ECU.
Ta
Toymax
Penrith
Re: FS Injectors Fri, 25 November 2005 11:46 Go to previous message
I've only ever used aftermarket ECUs, so I can't really help you there. They are 13.5 ohms resistence if that helps you. I can send you a photo to if you'd like.
Previous Topic:4AGTE Manifold and T3 Turbo
Next Topic:ST205 standard gear set - dissasembled
Current Time: Sun Nov 1 22:46:41 UTC 2026
Total time taken to generate the page: 0.0059869289398193 seconds
