Toymods » Tech & Conversions » Help needed! corona mkII light problems
Ta22lover
February 2005
icon3.gif  Help needed! corona mkII light problems Mon, 21 November 2005 16:48 Go to next message
Hi
I have taken out the light switch in my 1973 corona mkII rx-12, and put it back in again, but now no matter what i do, i only get the headlights to work, high and low beam are fine, but taillights, and interior lights are all gone. i have looked thru the fuses but no fuses are blow.
i found one "hidden" fuse in the engine room, but its not broke either, but im guessing its more hidden fuses.
can someone help me out?
thanks in advance
Ta22lover
February 2005
Re: Help needed! corona mkII light problems Fri, 25 November 2005 03:14 Go to previous messageGo to next message
I still havent figured this problem out.
still only my headlights works, no interior lights and no taillights works, and the car isnt charging anymore, and also seems to have happened something with the ignition in someway, cuz when i stop the car it has heavy afterburning.
i have found one wire that should have 12v power, but is now dead, its hooked up to the light switch, but i cant find any fuses or relays that wire is connected too.
if anyone knows about some relays or fuses somewhere on this car, please help
Re: Help needed! corona mkII light problems Fri, 25 November 2005 03:25 Go to previous message
I can't help but think you have inadvertently disconnected something.
If everything worked BEFORE you played with the headlight switch and AFTER you played with it, things don't work, then I'd start looking at what you played with.
Previous Topic:Why do i have a fuel line leaking into my chassis rail? (ke20 / ke25)!
Next Topic:20valve to gze ignition swap
Current Time: Wed Nov 18 13:12:59 UTC 2026
Total time taken to generate the page: 0.0061759948730469 seconds
