Toymods » Tech & Conversions » mx83 and 1jz install..q's about r154/1jz/computer setup!
stasi
mx83 and 1jz install..q's about r154/1jz/computer setup! Tue, 22 November 2005 05:28 Go to next message
have read that jzx81 chaser 1j's fits straight into mx83, and crossmember off chaser is not needed in the late 91/92 mx83, it bolts straight up.. i will be putting engine in with mechanic mate and boys help. this is wat im thinking, buy the jzx81 1j mark2 engine and r154 gearbox separate. I know id need to get a microtech ltx12. ill be able to get it wired up, but do i need to install the standard ecu for anything?!
is there anything else i need to keep in mind when putting in 1j and r154?! read that firewall needs to be bashed in a little bit for 154 to fit, apart from that anythign esle?!
[Updated on: Tue, 22 November 2005 05:29]
jasonp1977
Re: mx83 and 1jz install..q's about r154/1jz/computer setup! Tue, 22 November 2005 06:55 Go to previous messageGo to next message
the stock JZX81 auto ECU works fine with the R154. That's what I run in my R154'd chaser.
You need to bash the trans tunnel for box clearance, and need a custom tailshaft.
If you can get your hands on the pedal box and clutch master/line from a manual GX81 1GGTE frontcut then that's the neatest fit in the cressida.
stasi
Re: mx83 and 1jz install..q's about r154/1jz/computer setup! Tue, 22 November 2005 11:39 Go to previous messageGo to next message
cool, so just wire up stock ecu.. dont worry mate ill bash that trans tunnel for clearance!!
how much is the custom tailshaft?read that maybe 2 piece or best just get single custom?
is there anything else i could use instead of the pedal box and clutch master/line from a manual GX81 1GGTE?! just incase i can't get my hands on one of them?
also any probs with the 1j auto been converted to the manual with r154.. any gears cutting out, idel probs etc?!
jasonp1977
Re: mx83 and 1jz install..q's about r154/1jz/computer setup! Tue, 22 November 2005 12:53 Go to previous messageGo to next message
mine has zero probs running the auto ECU with the manual box. rev's to 7K cleanly in all gears, idles around 600rpm from what I can tell from the digital tach, cold idle and electrical idle up all work too.
I'm using a two-piece tailshaft with the front modified to take the R154 yoke, then both halves were balanced again after the mod.
stasi
Re: mx83 and 1jz install..q's about r154/1jz/computer setup! Tue, 22 November 2005 22:51 Go to previous message
will a microtech be needed for bigger single turbo conversion, prob a gt35 20psi??
or the standard ecu and 2j injectors work fine?!!
Previous Topic:Turboing a N/A 3SGE gen2?? whos done it
Next Topic:88-92 bumperb/taillight conversion??
Current Time: Fri Oct 16 10:05:32 UTC 2026
Total time taken to generate the page: 0.0051572322845459 seconds
