Classifieds » Engines, Accessories and other Mechanicals » SUPRA and SOARER PREDATOR COOLER KIT
RACESPEC
Forum Sponsor
SUPRA and SOARER PREDATOR COOLER KIT Tue, 22 November 2005 07:22 Go to next message
Hey Guys
We are proud to announce the release of the new PREDATOR COOLER KIT.
The Predator Intercooler System is a performance upgrade system specifically designed for high performance street, drag, circuit, and drift applications. Hand manufactured from polished aluminium, the 'bolt on' system comprises of an intercooler and radiator assembly that totally eliminates the need for front-end modification by utilising existing radiator mounts.
  • Horsepower is maximised through the use of cutting edge intercooler technology. Highly efficient integrated tube and fin straight through design improves heat transfer for less pressure drop, resulting in higher flow rate.
  • Short direct piping and high flow intercooler core means minimal boost pressure drop and turbo lag.
  • Safety and reliability issues are virtually eliminated through direct fitment and 'bolt on' features. No modifying required. Intercooler damage commonly sustained in on road incidents, and race and drift conditions are avoided.
Each Predator Intercooler System is the result of comprehensive research and development efforts undertaken right here in Australia.
Predator Intercooler Systems are100% Australian made and contain high quality waterproof / dustproof thermo fans, mandrel bent polished aluminium piping, five ply silicone hose, hose clamps, temperature switch, wiring kit, and are covered by a complete 12 month warranty.
We have them available for the
Toyota Soarer 1JZ 1992 - 1994
Toyota Supra 2JZ 1990 - 1997
http://www.racespec.com.au/upload/store/PREDATOR%202JZ.jpg
http://www.racespec.com.au/upload/store/PREDATOR%202JZ%201.jpg
$2997.50plus DELIVERY
Tarek
RACESPEC
boris
On probation
Brisbane, Queensland
Re: SUPRA and SOARER PREDATOR COOLER KIT Tue, 22 November 2005 07:52 Go to previous messageGo to next message
F#*&ing Sweet!
RACESPEC
Forum Sponsor
Re: SUPRA and SOARER PREDATOR COOLER KIT Tue, 22 November 2005 08:10 Go to previous messageGo to next message
Yeah, i thought so 2
and no need for the V-Mount Setups
Tarek
RACESPEC
chrisma70
no where
Re: SUPRA and SOARER PREDATOR COOLER KIT Tue, 22 November 2005 21:31 Go to previous messageGo to next message
none of these for a jza 70 setup...balls plz let there be one
1200det
Re: SUPRA and SOARER PREDATOR COOLER KIT Tue, 22 November 2005 21:59 Go to previous messageGo to next message
Would this reduce much flow to the Radiator ?
Wouldnt you also be getting Heat soak off the radiator to the intercooler when sitting at a standstill or on the Dyno ??
RACESPEC
Forum Sponsor
Re: SUPRA and SOARER PREDATOR COOLER KIT Tue, 22 November 2005 22:18 Go to previous messageGo to next message
Unfortunately, these are the only models they have them for
The Intercooler is a PWR Turbe and Fin, so air flow to the radiator is not hindered, unlike the BAR and PLATE coolers. This also allows for greater disappation of the heat
Tarek
RACESPEC
CD1J
April 2005
Re: SUPRA and SOARER PREDATOR COOLER KIT Wed, 23 November 2005 09:45 Go to previous messageGo to next message
would one of these kits fit a jzx90 mark 2?
Attachment: Image005.jpg
(Size: 63.99KB, Downloaded 28 time(s))
RACESPEC
Forum Sponsor
Re: SUPRA and SOARER PREDATOR COOLER KIT Wed, 23 November 2005 10:36 Go to previous messageGo to next message
I can not confirm nor deny this
They have been designed specifically for the
1JZ soarer and 2JZ supra
Tarek
RACESPEC
4runnerpetey
July 2005
Re: SUPRA and SOARER PREDATOR COOLER KIT Sat, 26 November 2005 00:33 Go to previous message
pretty nice gear bit too expensive though wouldve thought $2000.00 wouldve pulled it up.
Previous Topic:T-18 diff with swaybar mounts for AE86 LSD's
Next Topic:jza70\jzx90 hydraulic fan.pump.radiator.water pump.
Current Time: Mon Nov 2 14:27:18 UTC 2026
Total time taken to generate the page: 0.0077719688415527 seconds
