Toymods » Tech & Conversions » Standard AE86 spring rates (not a question)
shinybluesteel
melbourne
Standard AE86 spring rates (not a question) Tue, 22 November 2005 10:46 Go to next message
Hi all, i have some info which i thought you would all be interested to know.
I had some custom 4kg springs made the other day for a mate's daily drifter, and i had my standard sprinter springs measured for a laugh.
the rates are:
FRONT: 100 lbs/inch - 1.786 kg/mm
REAR: 110 lbs/inch - 1.964 kg/mm
so there you have it, not only are the standard rates quite weak, the rears are stiffer than the fronts.
[Updated on: Tue, 22 November 2005 10:53]
DRFT - 86
Batemans Bay, NSW
February 2005
Re: Standard AE86 spring rates (not a question) Tue, 22 November 2005 11:36 Go to previous messageGo to next message
haha. . . junk.........
out of interest........ as I have kingsprings in there.... not planning on keeping them .. but.
do they come in a set rate (just ur average 'low' king springs)...... does anyone know what they are if so..?
beige_bandit
September 2005
Re: Standard AE86 spring rates (not a question) Tue, 22 November 2005 21:11 Go to previous messageGo to next message
shinybluesteel wrote on Tue, 22 November 2005 21:46
Hi
the rates are:
Is this aus spec sprinter springs?
Henn
Rosanna, Melb
Re: Standard AE86 spring rates (not a question) Tue, 22 November 2005 22:20 Go to previous messageGo to next message
I priovided a stock spring as an example when I had custom springs made. The guy called back asking if I really wanted 5kg/mm springs for the rear because the factory ones were 1.2kg/mm. Maybe mine were particularly rooted.
Hen
shinybluesteel
melbourne
Re: Standard AE86 spring rates (not a question) Tue, 22 November 2005 22:41 Go to previous messageGo to next message
the rates i stated were for ADM springs.
i think there might be a difference between front rates or ride height (springs are marked with green and red paint) but i only got one front and one rear measured.
i'm running kings at the moment, rates for them (according to king's) are:
Front: 155 lbs/in - 2.77 kg/mm linear
Rear: 140/160 lbs/in - 2.5/2.85 kg/mm progressive.
my next springs will be 6kg/mm front 4kg/mm rear, but i keep changing my mind as i have adjustable swaybars too, and might be able to go down on spring rate.
6/4 is pretty good on the street though, and that is with fixed unknown rate shocks, adjustables should help lots.
hen, where did you get yours made?
[Updated on: Tue, 22 November 2005 22:45]
Xinx
Re: Standard AE86 spring rates (not a question) Wed, 23 November 2005 00:58 Go to previous messageGo to next message
Does anyone know the rate for a standard low Lovells springs? They don't seem to be as harsh as Kings spring that I had on the car before.
DRFT - 86
Batemans Bay, NSW
February 2005
Re: Standard AE86 spring rates (not a question) Wed, 23 November 2005 00:59 Go to previous messageGo to next message
cool, thanks for that mate.....
Callifo
Gawler, SA
Re: Standard AE86 spring rates (not a question) Wed, 23 November 2005 01:31 Go to previous messageGo to next message
Quote:
Our TFL-33 has a calculated rate of 145lbs/inch Our TRL-34 has a calculated rate of 170lbs/inch Approximate drop of 1 1/2" (38mm) on the front and 1" (25mm) on the rear
Xinx
Re: Standard AE86 spring rates (not a question) Wed, 23 November 2005 01:47 Go to previous message
Callifo wrote on Wed, 23 November 2005 12:31
Just as I thought the front is softer. I wonder if there is a reason why they would make the rear sit higher than the front? is it for handling or is it so people can carry their fat friend around?
Previous Topic:ke35 Advice
Next Topic:T50 Bell Housing Brace - Pics Inside
Current Time: Fri Oct 30 22:49:52 UTC 2026
Total time taken to generate the page: 0.01658296585083 seconds
