Toymods » Tech & Conversions » Can 20V bottom end fit 16V Head ?
Driftn86
Melbourne, Australia
Can 20V bottom end fit 16V Head ? Wed, 23 November 2005 02:42 Go to next message
Who has done this before? if possible Do the valves clear the piston. Even if you have cams with 8.35 lift
http://www.toyrolla.com.au/pictures/20v.jpg
http://www.toyrolla.com.au/pictures/16v.jpg
http://www.toyrolla.com.au/pictures/hks.jpg
illuminatus
eastern suburbs, melbourne
March 2005
Re: Can 20V bottom end fit 16V Head ? Wed, 23 November 2005 03:23 Go to previous messageGo to next message
do a search to verify, but im pretty sure the 16v and silver 20v bottem ends are the same(apart from pistons, but they should fit anyways).
ae86drift
sydney.au
Re: Can 20V bottom end fit 16V Head ? Wed, 23 November 2005 03:56 Go to previous messageGo to next message
block = yes
pistons/rods without some modification = pretty sure no
Shraka
Re: Can 20V bottom end fit 16V Head ? Wed, 23 November 2005 03:58 Go to previous messageGo to next message
Why would you want to fit a 16V head to a 20V bottom end?
What 16V are you using? Smallport or bigport?
Driftn86
Re: Can 20V bottom end fit 16V Head ? Wed, 23 November 2005 05:03 Go to previous messageGo to next message
big port.
So you get the hybrid setup!
Just like a 100kw bottom end and 86kw head.!
The best two bits.
have been told they fit but when i pulled the head off they look to different.
Driftn86
Re: Can 20V bottom end fit 16V Head ? Wed, 23 November 2005 05:05 Go to previous messageGo to next message
dotn have a computer or loom for 20v, plus i have been told there not that good engines anyway. 20V are cheaper than 16V now. Even a 86kw.
Johnny
Sydney, OZ
Re: Can 20V bottom end fit 16V Head ? Thu, 24 November 2005 04:14 Go to previous messageGo to next message
you'll need to change the pistons.
wraith
Albany WA
Re: Can 20V bottom end fit 16V Head ? Wed, 30 November 2005 06:05 Go to previous messageGo to next message
Johnny wrote on Thu, 24 November 2005 12:14
Johnny;
Are you 100%? I assembled something like this a couple of nights ago with std bigport cams & there were no marks on the bluetak on top of the piston Razz however with the piston at TDC I couldn't get much more than 20deg of the lobe down, so she's defntly an inteference setup...
Ash
Johnny
Sydney, OZ
Re: Can 20V bottom end fit 16V Head ? Wed, 30 November 2005 09:48 Go to previous messageGo to next message
Quote:
Are you 100%? I assembled something like this a couple of nights ago with std bigport cams & there were no marks on the bluetak on top of the piston however with the piston at TDC I couldn't get much more than 20deg of the lobe down, so she's defntly an inteference setup...
Ash
You'll change the combustion chamber's shape which may affect the way the mixture would ignite, ie cold spots... blah blah... I didn't say it couldn't be done, but what I was implying was it might not be wise to.
TerryOBeirne
Redbank Plains,near Ipswi...
Re: Can 20V bottom end fit 16V Head ? Sun, 04 December 2005 01:22 Go to previous message
in short, yes. however you will likely bend a valve if/when the cam belt breaks. The 20V pistons are not ideal for this use. you will also need the 16V oil pump and water pump, as the front plastic covers for the 16V won't line up on 20V stuff. also, you must use a 16V head gasket, as the 20V has quite different water passages. I dont think this is real clever idea, but hope this helps
Previous Topic:turbo sigma diff in a 86 questions
Next Topic:3SGE inlet/exhaust manifold profiles
Current Time: Fri Oct 30 06:21:09 UTC 2026
Total time taken to generate the page: 0.044526100158691 seconds
