Toymods » Tech & Conversions » 18RG Oil Pump Shaft and flow rates
filthman
Heathmont, Melbourne, Vic
18RG Oil Pump Shaft and flow rates Wed, 23 November 2005 06:07
Does anyone know if there is a shaft out of any other model engine that would be the correct length and diameter to use as a replacement oil pump shaft. I have the high flow 18RG pump currently which has snapped the shaft.
The pump section is attached with a pin but I need to find a compatible shaft without taking the sump off every car at pick-a-part.
Does anyone know the actual difference in flow rates / volume between the 18RG oil pump and the 18R / 20R / etc.
(Unless anyone happens to have an 18RG oil pump just lying around???)
Previous Topic:wondering about g'box variations
Next Topic:T50 REBUILD
Current Time: Sat Oct 31 14:43:49 UTC 2026
Total time taken to generate the page: 0.025070905685425 seconds
