Toymods » Tech & Conversions » 18RG Oil Pump Shaft and flow rates
filthman
Heathmont, Melbourne, Vic
18RG Oil Pump Shaft and flow rates Wed, 23 November 2005 06:10 Go to next message
Does anyone know if there is a shaft out of any other model engine that would be the correct length and diameter to use as a replacement oil pump shaft. I have the high flow 18RG pump currently which has snapped the shaft.
The pump section is attached with a pin but I need to find a compatible shaft without taking the sump off every car at pick-a-part.
Does anyone know the actual difference in flow rates / volume between the 18RG oil pump and the 18R / 20R / etc.
(Unless anyone happens to have an 18RG oil pump just lying around???)
Mr DOHC
Re: 18RG Oil Pump Shaft and flow rates Wed, 23 November 2005 09:08 Go to previous messageGo to next message
i have a few spare pumps
18RG and 18RC are the same cept for oil flow, as u already said
could be run for a short time till u get a spare pump
did u want dimensions
filthman
Re: 18RG Oil Pump Shaft and flow rates Wed, 23 November 2005 11:38 Go to previous messageGo to next message
Do you have a spare 18RG pump? I would be interested in that. How much do you want for it.
I figure that Toyota used the higher flowing pump for a reason after whatever testing they did on the engine, so I really want to keep the RG pump in it.
I know what the RC pump looks like so I don't need the dimensions, I was just interested in the actual flow difference.
Steve M
Re: 18RG Oil Pump Shaft and flow rates Thu, 24 November 2005 23:53 Go to previous message
I have been told by a guy at a Toyota parts dealership that one of the early M series engines had the same part number for the oil pump rotor (the bit that is not the same as the 18R). It might have been an M or a 2M, can't really remember for sure though.
Either way the part in no longer available from toyota.
Previous Topic:Mitsubishi Galant Sigma Arms into TA22: Failed!
Next Topic:info on a 4a-ge into a TA22
Current Time: Wed Nov 18 16:12:34 UTC 2026
Total time taken to generate the page: 0.0073890686035156 seconds
