Toymods » Tech & Conversions » 2JZ INTO MZ20
Dori Dori
2JZ INTO MZ20 Wed, 23 November 2005 09:52 Go to next message
Hi guys, i have started my 2JZ into MZ20 conversion and run into a snag.
My engine is a 97 VVTi 2JZ and the JZA70 cast alloy engine brackets wont bolt up. It seems that all is well on the older non-VVTi 2JZs but the bolt holes don't line up on the newer version engine.
Has anyone run into this issue?
The crossmember accepts the square engine mounts (7M) but neither the old 7M brackets, JZA70 will go onto the block.
Save from making custom mounts, I'm open to ideas.
EvilJack
Sutho/Hills NSW
Re: 2JZ INTO MZ20 Wed, 23 November 2005 09:57 Go to previous messageGo to next message
Grant, http://forums.toymods.org.au/index.php?t=msg&t h=52003&rid=1334&S=1c7d6d063e907b6e29dcafd 19a46b005&pl_view=&start=0#msg_476581
maybe a jza70 crossmember would be your best bet?
BlackSupra
Re: 2JZ INTO MZ20 Wed, 23 November 2005 10:00 Go to previous messageGo to next message
latter model mz20's got the same engine mounts as the jza70 as well.
Dori Dori
Re: 2JZ INTO MZ20 Thu, 24 November 2005 00:14 Go to previous messageGo to next message
The cross meber is not the issue. I am getting a JZA70 crossmember.
The issue is that the bolt holes on my VVTi block for the engine brackets are in a different location to a non VVTi engine.
In effect the intake manifold side engine bracket will not bolt on. Exhaust is ok.
Any ideas?
1JZ.747
Osama's hideout
Re: 2JZ INTO MZ20 Thu, 24 November 2005 00:21 Go to previous messageGo to next message
throw your hands in the air, say its too hard, and sell the 2j to your best mate for a cheap price, sell the soarer and by a pimped out ride. j/k
AE86slut
Baulko Hillo
Re: 2JZ INTO MZ20 Thu, 24 November 2005 00:32 Go to previous messageGo to next message
Bah, all sounds a bit too hard.
Buy a Sprinter and put it in that.
Dori Dori
Re: 2JZ INTO MZ20 Thu, 24 November 2005 00:38 Go to previous messageGo to next message
Thanks pole smakers.
stradlater
Arthurs Creek, Victoria
Re: 2JZ INTO MZ20 Thu, 24 November 2005 01:11 Go to previous messageGo to next message
Pole smakers? Or Pole Smokers?
MR 1JZ
Re: 2JZ INTO MZ20 Thu, 24 November 2005 01:21 Go to previous messageGo to next message
stradlater wrote on Thu, 24 November 2005 11:41
indeed...do they hit traffic lights or suck the wang? I am quite perplexed...
but seriously...how far off are the brackets? could the be redrilled or could new threads be tapped into the block?
Dori Dori
Re: 2JZ INTO MZ20 Thu, 24 November 2005 01:28 Go to previous messageGo to next message
Smackers. That will teach me to rush.
The brackets could be modifed or new ones made but i would like to use factory pats where possible.
MR 1JZ
wellllllll crank out the drill press Wink
Chris Davey
sunny coast, qld
Re: 2JZ INTO MZ20 Thu, 24 November 2005 01:36 Go to previous messageGo to next message
I am sure you already know this but just in case. There is 6 bolt holes on the jz engines. So have you tried both mounting locations? (4 bolt mounts)
Dori Dori
Re: 2JZ INTO MZ20 Thu, 24 November 2005 01:51 Go to previous messageGo to next message
On the exhaust side there are six on the intake side there are four.
In the early 2JZ and i think 1JZ (exhaust side) all six are in line. On the later model they are staggered. Again i think exhaust side should be ok only the intake side seems to be an issue.
i migh try an exhaust side bracket on the intake side and se if this fits.
i'll post pics tomorrow.
Cheers Guys.
AE86slut
Baulko Hillo
Re: 2JZ INTO MZ20 Thu, 24 November 2005 22:13 Go to previous messageGo to next message
Dori Dori wrote on Thu, 24 November 2005 12:28
factory pats
What's a "factory pat"?
Oh yeah, forgot to tell you. Your 2J is in and running. You missed out on it all because you were bludging at home.
1JZ.747
Osama's hideout
Re: 2JZ INTO MZ20 Fri, 25 November 2005 01:01 Go to previous messageGo to next message
i bet its been painted green too.
cause "green is nice"
AE86slut
Baulko Hillo
Re: 2JZ INTO MZ20 Fri, 25 November 2005 01:21 Go to previous message
1JZ.747 wrote on Fri, 25 November 2005 12:01
I prefer putting through the rough actually.
I only painted the seats.... And the inside of the windscreen.
Previous Topic:20valve to gze ignition swap
Next Topic:Mitsubishi Galant Sigma Arms into TA22: Failed!
Current Time: Wed Nov 18 13:13:15 UTC 2026
Total time taken to generate the page: 0.0085940361022949 seconds
