Toymods » Tech & Conversions » 2JZGTE difference from 2JZGE - psi
2J-BMW
November 2005
2JZGTE difference from 2JZGE - psi Wed, 23 November 2005 11:22 Go to next message
I just bought a 2jzgte and they guys did a compression test which came up as 180psi on all cylinders and i was going thought the manual they are rated at 156psi and the 2jzge is rated at 185psi,, is there any way they have just bolted the turbos to a 2gzje block? i think the heads are different? can anyone tell me a quick check to see if it is a 2jzgte block when the engine arrives, just want ot know that is a 2jzgte block when im making some big horsepower Smile
cheers.
also im swaping my front sump for a rear 1jzgte sump if anyone is interested as i heard 1jzgte sumps will fit the 2jzgte contact me on savo@onzone.com.au
[Updated on: Wed, 23 November 2005 11:25]
Alchemist
Re: 2JZGTE difference from 2JZGE - psi Wed, 23 November 2005 11:30 Go to previous messageGo to next message
Hi Mate, you can make big power from the 2JZ-GE block anyway, I know of people making 320RWKW from stock 2JZ-GE block(this is the N/A to Turbo conversion).
Go over to www.supraforums.com.au and have a trawl through the MKIV stuff, this has been covered alot.
2J-BMW
November 2005
Re: 2JZGTE difference from 2JZGE - psi Wed, 23 November 2005 11:42 Go to previous messageGo to next message
cheers man, checking out the site. just abit stressed with the 180psi. does anyone know if there is a crown on the 2jzge pistons that shouldnt be to hard to check with a tourch and wire.
Re: 2JZGTE difference from 2JZGE - psi Wed, 23 November 2005 22:38 Go to previous messageGo to next message
I'll bandy around a couple of theories.
1) Well for one, don't the 2JZGTE turbos not bolt to the 2JZGE head?
2) How was the compression test measured? There are a few ways that can be done, warm, cold, with a little bit of oil in the cylinders. If not done as same as the factory specs it could be different.
3) Perhaps it's been rebuilt recently or it's just a healthy engine. Confused
chetnik
canberra
Re: 2JZGTE difference from 2JZGE - psi Wed, 23 November 2005 23:31 Go to previous message
hi,
I really hope it is, i picked it becuase it was in a smash and the dash has been removed, i belive they do this because it has a low km's dash and they sell them off.
im think if any thing happend they have bolted a 2jzgte head with turbos on a n/a 2jzge block?
does any one have any 2jzgte piston pictures?
cheers 2J-BMW
[Updated on: Wed, 23 November 2005 23:49]
Previous Topic:Toyota Corolla Rim Offset
Next Topic:20 Valve - Black top modding options
Current Time: Mon Nov 2 06:06:54 UTC 2026
Total time taken to generate the page: 0.045789003372192 seconds
