Toymods » Tech & Conversions » 3SGE Gen 2 Cam options
Windex
Melburn!
June 2005
3SGE Gen 2 Cam options Wed, 23 November 2005 22:37 Go to next message
What are the options for a cam upgrade, I have been searching and have read in a post or two that the gen 2 wont accept higher lift cams without modification to the shim setup. Has anyone actauly upgraded their cams in a gen 2 or later? If so what did you go with?
Morten
Norway
November 2005
Re: 3SGE Gen 2 Cam options Sat, 26 November 2005 21:44 Go to previous messageGo to next message
You can use cams up to 9.XX mm lift with no problems. The HKS highlift cams (3.gen) with 264/272 might cause a problem. If you want/need bigger cams you can fix this by removing material from the "ramp". However it woud be a good idea to convert to either "shim-under-bucket" (like 3.gen) or "shimless-buckt" (using 1zz buckets) at the same time to eliminate the possibility of shims falling out on high revs if going bigger..
CelicaRA45
nth ringwood, Victoria
Re: 3SGE Gen 2 Cam options Sat, 26 November 2005 22:48 Go to previous message
you can put 12mm cams in if you wont but you need to change valve springs plus retainers plus you can buy new buckets from toyota that came from the gen 3 these are shim under buckets and you would have to buy 16 new shims as well
Previous Topic:4AGE diagnostic code 52?
Next Topic:2003 camry springs
Current Time: Wed Nov 18 17:19:05 UTC 2026
Total time taken to generate the page: 0.0212721824646 seconds
