Toymods » Tech & Conversions » 2t/3t electronic ingition
purpleminiep
Mentone
2t/3t electronic ingition Fri, 07 June 2002 03:18 Go to next message
Hi a friend of mine want to get rid of his points dizzy for a electronic dizzy. Anyone know of a similar toyota part that will work. Also anyone know of someone good with 2t experience to regraph it.
Brad
Pumpkin
Toymods Board Member
icon9.gif  Re: 2t/3t electronic ingition Fri, 07 June 2002 06:51 Go to previous messageGo to next message
Purpleminiep,
To my knowledge I dont know of any guts of the dizzy that will fit in the 2T dizzy... The only way I think to change it over to electronic is to get the distributer from a 3T-EU.. These should bolt straight in with no problems and they are electronic..
Jonny2TG
Tasmania
Re: 2t/3t electronic ingition Fri, 07 June 2002 14:01 Go to previous messageGo to next message
I have a 2TGEU dizzy myself. They are around, you just have to get lucky looking. There are some 4K/5K dizzys around with electronic ignition, mostly off import motors. SOme of these parts fit a 2T distributor. I have seen a few electronic ones on 2T motors, and 5K motors. I know FWD Gemini motors use the same distributor cap as my 2TGEU one, which is also the same cap as my 4K one. So look in a Gemini motor for parts. Its all ND as well.
purpleminiep
Mentone
Re: 2t/3t electronic ingition Thu, 13 June 2002 04:27 Go to previous messageGo to next message
We have fount a 3teu dizzy at EKW but htey do not have an ignitor. Does anyone know where we could finds one or what we could use instead of the original one.
Brad
Pumpkin
Re: 2t/3t electronic ingition Thu, 13 June 2002 05:16 Go to previous messageGo to next message
Purpleminiep
I am just using a 22RE ignitor and distributer on mine .... and it runs fine... No hiccups at all.. If you want I can have a look at mine and tell how it is wired up..
5KinKP60
Finland
Re: 2t/3t electronic ingition Fri, 21 June 2002 20:21 Go to previous messageGo to next message
'purpleminiep'
kits to replace points are plentyful.
as what comes to regraphing it, why not give a 'Jaycar programmable ignition' -kit a try. it's a low budget thingy, and not too complex to build. comes with good manual.
just my thoughts ...
Jonny2TG
Tasmania
Re: 2t/3t electronic ingition Sat, 22 June 2002 03:24 Go to previous message
If you can get a proper electronic distributor, I would not bother with a Jaycar kit using the points. Because you can still get points bounce and things car wear and slip still. A magnetic points setup is very robust. A hall effect system is technicaly better, but not as robust.
Previous Topic:New engineering/modifications guidelines?
Next Topic:RA40 heavy steering
Current Time: Sat Oct 17 03:03:57 UTC 2026
Total time taken to generate the page: 0.0070199966430664 seconds
