Toymods » Tech & Conversions » 2tgeu fuel pressure?
BEV051
agnes water qld
October 2005
2tgeu fuel pressure? Fri, 25 November 2005 01:08 Go to next message
hi I'm putting an efi system on my 2tgeu and wanting to know how much pressure ill need to run. and what fuel pump i could use. Will a 070 vl do, or do i have to use some think better like a 910 bosh.
[Updated on: Fri, 25 November 2005 10:44]
Re: 2tgeu fuel pressure? Fri, 25 November 2005 08:20 Go to previous messageGo to next message
Your 2T-GEU should have a fuel pressure regulator, and it will take care of the fuel pressure for you. Practically any EFI fuel pump will do the job unless you have some pretty crazy mods.
BEV051
agnes water qld
October 2005
Re: 2tgeu fuel pressure? Fri, 25 November 2005 10:42 Go to previous messageGo to next message
i dont have a fuel pressure regulater and need to buy one.
Re: 2tgeu fuel pressure? Sun, 27 November 2005 00:38 Go to previous messageGo to next message
So... do that then.
BEV051
agnes water qld
October 2005
Re: 2tgeu fuel pressure? Sun, 27 November 2005 02:25 Go to previous messageGo to next message
i just got one. it is an adjustable one and i need to know how much pressure i need to set it at. so if some body nows please let me know thanks.
[Updated on: Sun, 27 November 2005 02:26]
hemi twofifteen turbo
Re: 2tgeu fuel pressure? Sun, 27 November 2005 03:29 Go to previous messageGo to next message
most efi systems i've seen run 40psi. however not sure as to what 2t-g is. I'd be 90% sure it is though. if your running the std computer give it a shot at 40psi, if you've got aftermarket it's not as critical as u can tune for it, but still i'd run 40. I read an article about 2t-g injectors and all the flow rates were meausured at 40psi as well -- so again pointing towards 40psi. Hope this helps.
BEV051
agnes water qld
October 2005
Re: 2tgeu fuel pressure? Mon, 28 November 2005 07:09 Go to previous message
thanks ill give it a go when iv got it all together
Previous Topic:JZA70
Next Topic:4agte conversio q's
Current Time: Sun Oct 18 02:30:51 UTC 2026
Total time taken to generate the page: 0.024890184402466 seconds
