Toymods » Tech & Conversions » 4age keeps bouncing off 3-4 grand ???
GOLDEN86
June 2005
icon11.gif  4age keeps bouncing off 3-4 grand ??? Fri, 25 November 2005 07:36 Go to next message
Hey guys recently done ae86 4age conversion and keep getting revs bounces from 3-4 grand, it also reving a steady pace and 1 1/2 revs, what hell goin on ??
FKN16V
NSW, East Coast
Re: 4age keeps bouncing off 3-4 grand ??? Fri, 25 November 2005 09:24 Go to previous messageGo to next message
Wat does a diagnosis check tell you, im thinking bung sensor of some sort.
Does it drive good otherwise or is it a total dog. more intel would help.
Steve
GOLDEN86
June 2005
Re: 4age keeps bouncing off 3-4 grand ??? Fri, 25 November 2005 09:46 Go to previous messageGo to next message
How em suppose to diagnosis check ??
What sensor would i need to look to chek out ?
I havent drove it yet, but it revs steady to 4 grand and jus drops again, could be timming, i tried adjusting it, but not luck,but who know could be doing wrong
[Updated on: Fri, 25 November 2005 10:18]
Scorpion
Menai area of Sydney
Re: 4age keeps bouncing off 3-4 grand ??? Fri, 25 November 2005 21:16 Go to previous messageGo to next message
MAke sure all the vacuum tubes around the throttle body are blocked or connected to the right place. if unsure, block them off. Can you hear any air getting sucked in other than through the inlet opening ? You could try the idle speed screw on top of the throttle body in case someone has screwed it out too far.
Just screw it right in abd then unscrew it between half and two turns will get you close if that happens to be the problem. Has there been any work done on the engine during the transplant ? Be nice to know if anything has been touched since the engine was working in previous car. Are the MAP sensor and TPS connected ? MAP has loom and vacuum connection, TPS has loom connector. Car shouldn't run at all if MAP not connected but will if TPS not connected - albeit not too well.
[Updated on: Fri, 25 November 2005 21:18]
FKN16V
NSW, East Coast
Re: 4age keeps bouncing off 3-4 grand ??? Fri, 25 November 2005 21:32 Go to previous messageGo to next message
http://toymods.org.au/Repository/TechDocs/4age_boo k/efi/fi_22.jpg
and what it all means.
http://toymods.org.au/Repository/TechDocs/4age_boo k/efi/fi_26.jpg
Steve
raaf86
Kearns Campbelltown Sydney
June 2005
Re: 4age keeps bouncing off 3-4 grand ??? Sun, 27 November 2005 23:03 Go to previous messageGo to next message
u can also check if all the injector cables are all pluged in the right place, happened onced with my mate.
GOLDEN86
June 2005
Re: 4age keeps bouncing off 3-4 grand ??? Mon, 05 December 2005 11:04 Go to previous message
Injectors are fine, everyone thought was TPS since when i took it off it would rev pass 4 grand, but when i plug it back it will just bounce of 4 grand
I just replaced TPS sensor, still doing it Sad
[Updated on: Mon, 05 December 2005 11:07]
Previous Topic:Gearbox trouble (4A-FC)
Next Topic:No TPS = No Balls ?
Current Time: Thu Nov 19 00:30:55 UTC 2026
Total time taken to generate the page: 0.0066640377044678 seconds
