Toymods » Tech & Conversions » AE93 4agze conversion (gearbox)
Sherman
August 2005
AE93 4agze conversion (gearbox) Fri, 25 November 2005 21:37 Go to next message
Hi Guys,
Can anyone explain what is neccessary to bolt up a 4agze LSD gearbox with its massive drive shafts to a standard sx rolla 4age block. Thank you.
jasonp1977
Re: AE93 4agze conversion (gearbox) Sat, 26 November 2005 09:46 Go to previous messageGo to next message
clutch, flywheel, AE92 GZE rear engine mount, GZE shafts, E series mechanical speedo sender.
enki
Re: AE93 4agze conversion (gearbox) Sat, 26 November 2005 10:29 Go to previous messageGo to next message
Im planning on doin this also but one thing i found that could go wrong and will probably find out later when i actually try to do it is that the longer shaft has a bracket that bolts up to the back of the engine block to hold it in place no to sure how im gonna fix this problem but find out later. Also people have mentioned that the ratios and gear set is not appropriate for na cars and will most likely loose power rather than gain i say have a go cos they said the exact same thing for my friends car when he put an ep82 starlet gearbox in a corolla 2 gp turbo and it worked sweet as.
Sherman
August 2005
icon14.gif  Re: AE93 4agze conversion (gearbox) Sat, 26 November 2005 20:23 Go to previous messageGo to next message
Thanks guys, I'll have a crack at it and report back with the results.
Cheers!
evoX3
November 2005
Re: AE93 4agze conversion (gearbox) Sun, 27 November 2005 10:37 Go to previous message
you could use the AE95 ratios or RAV4 ratios if you like,RAV4 has uprated syncros if your keen enough they should fit
Previous Topic:7mge dimensions
Next Topic:English Install Manual for Blitz Dual SBC Spec R
Current Time: Thu Oct 22 11:55:45 UTC 2026
Total time taken to generate the page: 0.0051441192626953 seconds
