Toymods » Tech & Conversions » what tyre pressures you running?
joshdrift
Banned Troll
bankstown
November 2005
icon14.gif  what tyre pressures you running? Sun, 27 November 2005 20:12 Go to next message
just wondering what tire pressure you all run for drifting?ive been using 40psi,but hoped someone might be able to give me the optimal tyre pressure for drifting.my rear seems to grip to much and isnt hanging out like it should.
josh
yrhkira
June 2005
Re: what tyre pressures you running? Sun, 27 November 2005 23:05 Go to previous message
Josh,
Cannot help with optimal tyre pressures.
Basically to lessen the grip at the back try dropping rear pressures down from the 40psi. Keep the fronts at 40psi, ideally when hot.
Start with rears around 32 to 34psi, then go for a run. If the outside edge is starting to roll over and there are signs of wear passed the little triagulated tyre wear indicator markers then maybe increase the pressures a little.
Tyres form part of the suspension of the car. Increaseing the rear tyre pressures stiffens up the rear tyre sidewalls, this reduces the tyre roll over, hence more tread on the raod and more even grip across the two rear tyres and that means usually the car has a bit less steering at the front.
The idea is to reduce the grip of the outside rear tyre by increasing the tyre roll over and hence resulting in less grip available for turning so the outside tyre starts to slide sooner, which is exactly what is needed in drifting.
As an allternate. Increasing the roll stiffness by using a heavier rear swaybar increases front end steering and reduces rear end grip.
Regards
Rodger
Previous Topic:Urgent help! AE92 Corolla
Next Topic:4agze blowing black oilly resedue
Current Time: Sun Oct 18 20:00:34 UTC 2026
Total time taken to generate the page: 0.0050630569458008 seconds
