Toymods » Tech & Conversions » 4AGZE INTO RWD SPRINTER
Slippy
March 2005
4AGZE INTO RWD SPRINTER Mon, 28 November 2005 00:32 Go to next message
Quick question. I am putting a 4agze into my ae86 using the same t50 gearbox. I am going to put a decent clutch in while it is all apart but just unsure which one to order. Im pretty sure it is the clutch to suit the 4agze. Is this correct?
Thanks./.
beige_bandit
September 2005
Re: 4AGZE INTO RWD SPRINTER Mon, 28 November 2005 00:52 Go to previous messageGo to next message
You'll need a 20v or 16v 4AGE flywheel and clutch to fit in a t-50
bellhousing!
4AGZE setup to big for t-50 bellhousing with out some modification
Re: 4AGZE INTO RWD SPRINTER Mon, 28 November 2005 01:30 Go to previous messageGo to next message
on top of that, the 4agze E58 gearbox (fwd) uses the bigger input shaft spline the same as the W50, W58 etc rwd boxes..... thus a 4agze clutch disc would be completely useless with a T50 gearbox.
Do as the person above suggests.... and be careful with that glass cased box there!
Andor
May 2005
Re: 4AGZE INTO RWD SPRINTER Mon, 28 November 2005 08:10 Go to previous messageGo to next message
So if you use a W5X gearbox with a custom bellhousing you can keep the std flywheel and clutch?
Re: 4AGZE INTO RWD SPRINTER Mon, 28 November 2005 08:20 Go to previous messageGo to next message
yes you can keep the gze flywheel and clutch.
although its about a $1000 exercise Smile
Re: 4AGZE INTO RWD SPRINTER Mon, 28 November 2005 12:05 Go to previous messageGo to next message
...but then think of how much better it is to do that than spend 3 times that much replacing T50s Laughing
Slippy
March 2005
Re: 4AGZE INTO RWD SPRINTER Mon, 28 November 2005 20:56 Go to previous messageGo to next message
Ok so to cut a long story short I need a 4age clutch. I allready have one and also the flywheel but need a new one as my clutch is rooted. The 4agze clutch is 20mm larger in diametre if I remember correctly.
So I will be fine if I go and purchase a RWD 4age clutch? :)Smile
beige_bandit
September 2005
Re: 4AGZE INTO RWD SPRINTER Mon, 28 November 2005 21:43 Go to previous message
Any 20v or 16v rwd or fwd setup , just not a gze setup.
But as mentioned above $1000 aprrox versus replacing a blown t-50
when its had enough, because your running a 4AGZE you'll have problems with the t-50, but you could always see how you go with the t-50, it just wont put up with a lot of stick.
Previous Topic:Problem solved, Please delete.
Next Topic:3SGTE timing issue - now actuator issues
Current Time: Thu Oct 29 14:47:38 UTC 2026
Total time taken to generate the page: 0.027408123016357 seconds
