Toymods » Tech & Conversions » Cressida conversion 1jz-gte vs 2jz-gte
Ollygt
Cressida conversion 1jz-gte vs 2jz-gte Sat, 18 January 2003 12:51 Go to next message
1jz-gte vs 2jz-gte
I know a lot of people have done the 1jz-gte into the cressida, is there a reason why the 2jz-gte isn't done? is it problems with fitting, high cost? Its just that a lot of people say that the chaser front cuts are getting hard to find. And by the time I can rig it all up It'll probably be even harder to source one.
Re: Cressida conversion 1jz-gte vs 2jz-gte Sat, 18 January 2003 21:40 Go to previous messageGo to next message
Basically it stems around the fact that say you had an MX83 Cressida, if you got a JZX81 Chaser front cut, everything would swap over, much easier than custom making a heap of stuff.
Ollygt
Re: Cressida conversion 1jz-gte vs 2jz-gte Sun, 19 January 2003 11:04 Go to previous messageGo to next message
Ahh fair enough and from some emails I got it seems the 1jz-gte is a fine engine as it is, except for that Y piece on the two turbos.
mx83toy
Re: Cressida conversion 1jz-gte vs 2jz-gte Tue, 21 January 2003 08:44 Go to previous messageGo to next message
the 1j is a great engine but the 2j would be nicer for slow cruzing this is the only time i miss the 7M's extra .5 liters THE ONLY!!! time the 1j is supirior in EVERY other respect... the 2j could only be better.....i bet the conversion wont be as easy or as OEM as mine though Wink
EMP-2TG
Carlingford, Sydney
Re: Cressida conversion 1jz-gte vs 2jz-gte Tue, 21 January 2003 23:02 Go to previous messageGo to next message
but how hard is the convertion to a 2jz?
anyone know any sites on it?
Re: Cressida conversion 1jz-gte vs 2jz-gte Tue, 21 January 2003 23:34 Go to previous messageGo to next message
MX83 is 'sort of' like an MA70. Arnout has a website outlining the installation of a 2JZGTE into an MA70. This will give you some clues.
I think the website is www.supras.nl (or something like that).
EMP-2TG
Carlingford, Sydney
Re: Cressida conversion 1jz-gte vs 2jz-gte Wed, 22 January 2003 00:12 Go to previous messageGo to next message
thanks GT Smile
looks like a damn good site
mx83toy
Re: Cressida conversion 1jz-gte vs 2jz-gte Wed, 22 January 2003 00:23 Go to previous messageGo to next message
well what id do if i were you... msg jayzee i think he has a spare jzx81 cross member.. if memory servs me well the 1j and 2j mounts are exactly the same.... shape, pattern and location i guess this would be a good starting point for the convo....this way there is no chopping and welding and the steering and suspention can stay the same....you could use the cressi radiator and the gbox crosmember off the cressi should fit or be easily modded to fit....the speedo cable should screw in and grant from sixworks has made a converter so your tacho works...what you'll have to sort out is the wiring and a coola other that that you'll need pacients, money and time ohh and pacients....good luck
Re: Cressida conversion 1jz-gte vs 2jz-gte Wed, 22 January 2003 01:22 Go to previous messageGo to next message
The 1JZ engine mounts I have seen (from a JZA70) are very different to the engine mounts that were on my 2JZ. The mounting points on the block are identical though, so you can put 1JZ mounts on a 2JZ block or vice versa.
Remedy
Southern Sydney
Re: Cressida conversion 1jz-gte vs 2jz-gte Wed, 22 January 2003 01:30 Go to previous messageGo to next message
hmmm and mabye a spell checker.... Laughing
Hang on there is one... your just lazy. Mad
Re: Cressida conversion 1jz-gte vs 2jz-gte Wed, 22 January 2003 01:49 Go to previous messageGo to next message
Remedy wrote on Wed, 22 January 2003 12:30
your just lazy.
You really mean you're, don't you..... Embarassed
ed_ma61
Lost in the K hole
Re: Cressida conversion 1jz-gte vs 2jz-gte Wed, 22 January 2003 01:53 Go to previous messageGo to next message
[quote title=Remedy wrote on Wed, 22 January 2003 12:30]
and what the hell is mabye ??
hehehe
ed
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon10.gif  Re: Cressida conversion 1jz-gte vs 2jz-gte Wed, 22 January 2003 01:53 Go to previous messageGo to next message
Shame there's no grammar checker huh? Wink
Remedy
Southern Sydney
Re: Cressida conversion 1jz-gte vs 2jz-gte Wed, 22 January 2003 01:56 Go to previous messageGo to next message
I did that on purpose to prove my point!!!
Thats right.... almost sounds believable too.
ed_ma61
Lost in the K hole
Re: Cressida conversion 1jz-gte vs 2jz-gte Wed, 22 January 2003 01:59 Go to previous messageGo to next message
hehehe "i was just checking"
Re: Cressida conversion 1jz-gte vs 2jz-gte Wed, 22 January 2003 02:02 Go to previous messageGo to next message
Hehehe
mx83toy
Re: Cressida conversion 1jz-gte vs 2jz-gte Wed, 22 January 2003 03:40 Go to previous message
Twisted Evil Razz yeah i knew there was something common with the mounts!!! (sorry Embarassed) i gotta type quick cuase i'm at work ad stuff
I"M NOT LAZY!!!!!
remedy shut up!!!! Smile
[Updated on: Wed, 22 January 2003 03:41]
Previous Topic:I cant locate the coil for a 4afc engine. TACHO installation
Next Topic:WHen did Toyota start puting in Rev Limiters?
Current Time: Fri Nov 20 10:39:10 UTC 2026
Total time taken to generate the page: 0.028666019439697 seconds
