Classifieds » Parts Wanted » 18RG Valve Shims.
crowncustom
Devonport Tasmania
November 2005
18RG Valve Shims. Mon, 28 November 2005 13:44 Go to next message
Hi all I am in need of a set of valve shims for an 18RG.I have just started rebuilding one and the head I have found does not have any in it what so ever.I need a set of 40 thou and 50 thou.Also need if someone out there has them,a full set of 18R not RG 20 thou up pistons.
Cheers Brett.
CelicaRA45
nth ringwood, Victoria
Re: 18RG Valve Shims. Wed, 30 November 2005 05:38 Go to previous messageGo to next message
the shims start from 1.75mm up to 3.20 mm for 18rg and cost about 12 dollars each so you need to buy a couple or what a friend of mine did was buy 8 from me and set it up to get the right sizes then send mine back for a change over
ra_28
Re: 18RG Valve Shims. Thu, 01 December 2005 22:53 Go to previous messageGo to next message
F*ck play around with the shims for an 18rg to hard to get a perfect gap you need a facing machine to grind the shims your better off taking the head to head reco shop an having it done.
andrewvibert
Forum Sponsor
Shepparton (Vic)
Re: 18RG Valve Shims. Thu, 08 December 2005 00:38 Go to previous messageGo to next message
I have damn near a full set of shims. Cost is $10 each. Let me know what thickness shims you require.
o_man_ra23
Townsville North Qld
icon10.gif  Re: 18RG Valve Shims. Fri, 09 December 2005 04:31 Go to previous messageGo to next message
If you have no shims at all, you will need a test set to guage your clearances. 1 would do it if you have time to spare, but you will need one that is too small or ever so slightly too big for each valve, and then order the correct sizes accordingly.
crowncustom
Devonport Tasmania
November 2005
Re: 18RG Valve Shims. Sun, 11 December 2005 10:51 Go to previous messageGo to next message
It would be fine if I was in the same town or even state for u to do a test set up for me but Tasmania is a very long walk to where u r Laughing .Basically what would be good if someone wanted to sell me a stuffed head with shims or just the shims out of one but long as though they were packed together and marked which lot of shims came from what valves.
PLZ someone must have some lying around not being used and CHEAP.
Cheers Brett.
crowncustom
Devonport Tasmania
November 2005
Re: 18RG Valve Shims. Sun, 11 December 2005 10:54 Go to previous messageGo to next message
By the way the head I have is a 253 stamped head one of the decent early ones.
o_man_ra23
Re: 18RG Valve Shims. Sun, 11 December 2005 13:58 Go to previous message
doesnt matter what valve from what head they are from. There was some motorbike they were the same as... cant remember which one, but i did see it once... probably on classic-celica.com
go and take the head to your local motorbike specialist, they may be able to figure out what ones you need. I might have a look out the back, dont think i have any spares tho.
Previous Topic:WTB: 20v TRUMPETS!!
Next Topic:parts for 20v rwd conversion URGENTLY
Current Time: Sun Nov 22 18:31:21 UTC 2026
Total time taken to generate the page: 0.050577878952026 seconds
