Toymods » General Car Talk » Post Your Dyno Day Result
IRA11Y
Club Member
icon1.gif  Post Your Dyno Day Result Sun, 19 January 2003 01:34 Go to next message
Well Im home early to look after the ankle biter so I may as well start the thread Smile
I have to say I dont think Ive seen so many people so early at a dyno event, if youre not there and you have nothing on, get your ass down there cause it looks like its going to be a top day!!!!
now to the result.
KE70 4AC 52.9 RWKW
read it and weep....watch out all you 4AGE people here I come Smile
Dyno Sheet
[Updated on: Sun, 19 January 2003 07:37]
ae86trueno
Re: Post Your Dyno Day Result Sun, 19 January 2003 01:57 Go to previous messageGo to next message
ok well im home early to
AE86 4AGE 62.9 RWKW
when i left it was the fastest 16V 4AGE, but im sure someone will go better
now where have i misplaced those missing 4 valves??
The 4WD 20V was very good
Ben
AE86 Trueno 4AGE
wilbo666
Re: Post Your Dyno Day Result Sun, 19 January 2003 02:46 Go to previous messageGo to next message
[quote
KE70 4AC 52.9 RWKW
[/quote]
Whoa thats pretty good man! (can't wait to see how many of the 4AGE's you beat lol)
What has it had done to it?
Remedy
Southern Sydney
Re: Post Your Dyno Day Result Sun, 19 January 2003 06:30 Go to previous messageGo to next message
A little disapointed that my plugs fowled up so much.... will be replacing them quick smart.
However not all together unhappy with 157.7RWKW.
Hope everyone enjoyed themselves.
Click Here if you want to see my printout.
EvilJack
Sutho/Hills NSW
Re: Post Your Dyno Day Result Sun, 19 January 2003 07:34 Go to previous messageGo to next message
64 FWKW
http://sydcorollaclub.cjb.net/dyno%20day/
check there for pics of the day, not many but some didnt turn out Sad
[Updated on: Sun, 19 January 2003 07:35]
[mikey]
Re: Post Your Dyno Day Result Sun, 19 January 2003 07:58 Go to previous messageGo to next message
AE82
148.2 FWKW
was a nice day, but beach was even better!!
Michael
EvilJack
Sutho/Hills NSW
Re: Post Your Dyno Day Result Sun, 19 January 2003 08:12 Go to previous messageGo to next message
are the dyno readout sheets kept at all?
i forgot to pick mine up Crying or Very Sad
SUPRAGTE
North Sydney
Re: Post Your Dyno Day Result Sun, 19 January 2003 09:24 Go to previous messageGo to next message
Remedy, you'll pick up around 15rwkw if you can sort out that over rich fuel with a Fuel Only computer.
You'd see around 175rwkw! You could say you pretty much had that figure. Smile
Bugman
Re: Post Your Dyno Day Result Sun, 19 January 2003 09:25 Go to previous messageGo to next message
I was kinda dissapointed as I got my dyno done as the a/f sensor was dying.. and got weird results, the next few people went without a a/f ration on their dyno, until they fixed the sensor.
SUPRAGTE
North Sydney
Re: Post Your Dyno Day Result Sun, 19 January 2003 10:15 Go to previous messageGo to next message
Anyone going to post the results in a list?
Was the 321rwkw the highest of the day from the MK4 Supra?
St3ve_AE92
South of Wollongong
Re: Post Your Dyno Day Result Sun, 19 January 2003 11:09 Go to previous messageGo to next message
http://www.toymods.org.au/msgboard/index.php?t=msg &th=8769&rid=139&S=49ff68aab20684da9ce 031002981312d&pl_view=&start=0#msg_70313
Sam
Sydney, Australia
Re: Post Your Dyno Day Result Tue, 21 January 2003 00:07 Go to previous messageGo to next message
I'll post my graph up later after I scan it...
the 4AGE (100kW) pulled 59.4kW.
At 100km/h my tacho reads 3500rpm, on the dyno graph the power really flattened out at around 150km/h which I estimate to be 5200rpm, so I reckon there's some gains to be made..
I've posted up a couple of pics in the results thread as well.
rgrds
sam
7mgtema71
Re: Post Your Dyno Day Result Tue, 21 January 2003 01:53 Go to previous messageGo to next message
I dyno'd the celica (std 2TG in a ta22) and managed a little 54rwkw using std 40mm solex's. Reason for the dyno was to compare before and after dyno readings for when i fit my custom efi gear onto it.
As for the MKIII supra i managed 183rwkw with 15psi through a high flowed CT26. Std cooler and ecu and piping. Still plenty more to see here...
Keep up the good work and make sure the Toyota name never dies!
rvrolla
Central Coast
Re: Post Your Dyno Day Result Tue, 21 January 2003 03:11 Go to previous messageGo to next message
119RWKW
Bog stock 7MGTE. Haven't even changed the plugs on it since I've owned it. Could get more, but hey, I have a figure to work off now ! Very Happy
mmmm 15psi.... Wink
7mgtema71
Re: Post Your Dyno Day Result Tue, 21 January 2003 03:28 Go to previous messageGo to next message
Mine bog stock was 133rwkw at 7psi when i first had it serviced. It did have an aftermarket air filter and BOV though.
rvrolla
Central Coast
Re: Post Your Dyno Day Result Tue, 21 January 2003 04:45 Go to previous messageGo to next message
Mines only running the standard 5 - 5.5 psi... Rolling Eyes
Johnny
Sydney, OZ
Re: Post Your Dyno Day Result Wed, 22 January 2003 12:33 Go to previous messageGo to next message
I'm still spewing Mad NO RESULT!! Mad So I've got know Idea on standard, and I'll take it I'll have know idea once some mod's are done... grrr Mad
IRA11Y
Club Member
Re: Post Your Dyno Day Result Thu, 23 January 2003 07:45 Go to previous messageGo to next message
Wilbo666
the engine ...believe it or not.... is stock standard...in fact I dont even recall where I got it from as it was one I just pulled from under the house that was left over from one of the conversions I did for someone. The only changes Ive made are to fit a short 2" section about 1.5 feet long after the factory header ( a left over from one of my wrecked sprinters) the rest of the exhaust is stock 1.75", I also pulled out the exhaust butterfly/carby warmer to improve the flow. Other than a $10 6" air filter thats all thats differnt...in fact if anything it should be running crap because the coil is on the opposite side of the engine bay to the dizzy and I just dodgely connected two leads together to reach all the way accross Smile, and it shorts on the firewall from time to time LOL
Bounty
_Sydney _
Re: Post Your Dyno Day Result Thu, 23 January 2003 09:16 Go to previous messageGo to next message
I got sort of a non dyno day result, I didnt put my car on since i had it booked in at croydon on tuesday to get my safc installed so i got 194.6KW at abt 15psi. am i still eleidgable for a trophy? Razz
juzzo84
Hornsby, N.S.W
Re: Post Your Dyno Day Result Thu, 23 January 2003 10:45 Go to previous messageGo to next message
GEOFF, red fascination celica 2tg, 58.8RWKW
NICK, 89 celica grey 3sge, 69.0 FWKW
I would have bought my celica along, but i fucked the diff on the way home from the beach with my girl, so its in the garage getting R&R.
JUZZO
[TOYROTA]
A.C.T
Re: Post Your Dyno Day Result Fri, 24 January 2003 05:37 Go to previous messageGo to next message
Can i post my mates dyno readout here, even if it isn't a Toyota and wasn't done on the dyno day? Prob not but i'll do it anyway. 798hp@ THE WHEELS!!! Yep Ivan's pink 13Bturbo RX3 sedan sure stirred the V8 yobbo crowd at this years summernats... hehehe. I'd like to see a 1.3litre V8 put out 800hp @ the wheels lol noooooooooo chance. Laughing
[Updated on: Fri, 24 January 2003 05:38]
Malicia
Re: Post Your Dyno Day Result Sat, 25 January 2003 11:57 Go to previous messageGo to next message
"Off Topic"
[TOYROTA]: Do you live in kaleen near the little shops with the servo??
if so you might have seen a white rx3 a few times, He's my sister mate. Its got a 13b turbo with a MASSIVE truck turbo, intercooled and fully rebuilt, It pumps out over 900hp. If you see it try flag him down his name is troy.
[TOYROTA]
A.C.T
Re: Post Your Dyno Day Result Sun, 26 January 2003 00:46 Go to previous messageGo to next message
I live in Giralang but when you started describing the RX3 i was just thinking it was my mates 9second PROTECH one. However you say his name is troy hey? Can you give me more details on it, sounds interesting. My mate also lives near the kaleen shops with his RX3, his name is Mark though, his also runs a large truck turbo, front-mount 'cooler, and it's mini tubbed with 4inch cheese cutters on the front. Perspex windows the lot. He's been doing runs lately and beat Youssef's brother in that tubbed-out black Vb Commodore, you know the one. Rowan also beat the commie in his Orange RXEngineering RX3 by about 5 carleangths! Good race. Muz got ticked off and now he's putting NOZ on it to try and beat Rowan. He'll still loose i reckon.
André
[Updated on: Fri, 31 January 2003 02:56]
Bandit
Cranebrook, Sydney
Re: Post Your Dyno Day Result Sun, 26 January 2003 11:48 Go to previous messageGo to next message
Ok guys i know everyone has impressive dyno results.
But i was amazed at mine....So were a few others.
I have a simple KE70 Rolla with a 4KC engine.
She pulled a mighty 46.1kw at the rear wheels. It was so funny watching Irally's jaw drop as my rolla cleared the 40 mark. i was only 6kw off his 4AC KE70. So in a drag it would come down to driver ability. Next dyno day i do plan to beat my output using the same engine.
I was hoping to beat irally but i have been told that he will have a new engine by then. But i still plan to clear 52.9kw.
TheStitt
Membership Secretary
Re: Post Your Dyno Day Result Sun, 26 January 2003 23:14 Go to previous messageGo to next message
Don't know how but I managed to claim top single cam. With a Staggering 57.1 kw at the rears in my 4MU powered crown wagon. I coundn't belive it then again the had had less than 400 miles on it. Lets play around with the fuel for next time.
IRA11Y
Club Member
Re: Post Your Dyno Day Result Mon, 27 January 2003 07:30 Go to previous messageGo to next message
Stitt
its easy to see how you won....you were in a class of your own, its pretty much impossible for a 4A to beat your bigger cc engine......but you never know theres always next dyno day if I can be bothered keeping the C in for that long Smile
Maybe a class requirement might make more sense at the next dyno day otherwise any big cc singlecam can be made to win easily which means that its a little pointless for the guys who dont have the bucks to step up to twincam engines but still want to tinker with thier singlecams for a better dyno result.
Itll also mean youll always walk home with a trophy Stitt LOL
[Updated on: Mon, 27 January 2003 07:37]
Malicia
Re: Post Your Dyno Day Result Tue, 28 January 2003 03:44 Go to previous messageGo to next message
[TOYROTA] I spoke to my brother inlaw to see if i got the name wrong but I didn't his name is troy, He lives in hall but is always at my sisters house, He said he raced your friend on the federal highway and beat him by a car length.. He also raced a new M3 and beat it so bad he stopped to ask if something was wrong with it.
TheStitt
Re: Post Your Dyno Day Result Wed, 29 January 2003 07:21 Go to previous messageGo to next message
Irally
I'm not by myself in that single cam catagory I only beat Joe's corona by 2.1kw and its got some mods I had a carby issue.
However you are right and cubes are always going to win this battle. Again though you want to start spliting the catagory's up even more. I was happy to comepte against the other N/A over 1600's the top single cam was a bonus and something I didn't expect.
IRA11Y
Club Member
Re: Post Your Dyno Day Result Thu, 30 January 2003 09:58 Go to previous messageGo to next message
Its not about splitting the categories up (although to get the result of what Im about to say, you basically have to do just that) its about enticing people to compete, lets face it if someone came in with a big (say 9.0L) straight 12 cylinder and beat you by 50Kw I dare say you'd not bother spending dollars on your engine to try and beat them, but if you were in a class where youre result was only 2-6KW around the other competitors wouldnt you want to try and do something for the next dyno day??
The fact is that if you are going to have a trophy specific to a type of engine, i.e singlecam, then you need to make it possible for everyone to have a crack at some ego boosting..and lets face it thats what we all enjoy, when everyones talking about your result it makes you feel good, if it doesent then youre in the wrong hobby shop Smile
at the moment we allready have a hell of a lot of awards in different categories and to be honest I wasnt even aware of the singlecam trophy till after Id run the car on the dyno. With so many trophys allready split in to different classes it would have been logical it seems to me to do the same with any new trophy as well.
I guess were never going to all be happy with the different classes, as it is theres some big divisions in the categories. I guess the main thing is we are all having fun trying Smile
[TOYROTA]
A.C.T
Re: Post Your Dyno Day Result Fri, 31 January 2003 02:54 Go to previous messageGo to next message
HAHA OHHHHHH i know what you're talking about now!!! lol. Ahh yes i met Troy, i was there the night he raced Mark on the highway. If it's who i'm thinking, Troys car is a white RX2 with a 13B turbo running an automatic mazda box. It's got a big front 'mount and a nice oil cooler directly under the front. It's got the series 2 headlights (twins) and it's running some 17inch 6 spoke silver rims. Yeah ask troy, he probably remmembers me, i was wearing my tommy jumper and a red hat, i was talking to him for a while. Yeah those races were very contoversial lol (not really). We initially decided where to race but some looser listened-in and told all his mates where the runs were going to be. We all split-up in Braddon and i left with Mark. But when we approached the location where we were to race, we saw about 20 cars lined up waiting for us to race. So we said f%$#^ this and turned around and then we called troy and told him to meet us somewhere else. but the place wasn't ideal and a full 1/4 mile wasn't really do-able cause if the next set of lights went red there would be a prob. Even though it was the middle of the night out in the middle of whoop-whoop, not a car to be seen, there's always the chanch you know. So the two guys were only doing 1/8ths and backing off. Mark won the first run, then troy beat mark the 2 next times, however it was clear from everybody watching that marks car was quicker. Troy kept getting crazy launches and getting mark off the start who is still trying to set up his stall converter properly, then mark would start chasing him down at 1/4 track but then troy would back-off before Mark had time to real him in. Good fun but. Apparently it was Troys first proper run since his car has been finished. He did a good job, gotta be happy with that! Seems like a nice bloke.
Andre
kingmick
Banned by his request
moved to tamworth
Re: Post Your Dyno Day Result Sat, 01 February 2003 11:35 Go to previous messageGo to next message
bounty,
if its on croydon's dyno that means on a normal dyno you would have 120kw's hahaha
sorry couldnt help myself:)
mick
Bounty
_Sydney _
Re: Post Your Dyno Day Result Sun, 02 February 2003 04:45 Go to previous message
Razz yeah ive heard there dyno reads high ill put it on another dyno one day maybe next dyno day.
Previous Topic:street Rod 3 is out!!!!!!!!!!!!!!!
Next Topic:Go the TA22
Current Time: Wed Oct 21 02:57:49 UTC 2026
Total time taken to generate the page: 0.025564908981323 seconds
