Toymods » Tech & Conversions » diagnostic codes 12,24
chug
October 2005
diagnostic codes 12,24 Tue, 29 November 2005 07:57 Go to next message
hi guys,
i ran the test and these codes popped up, i have searched and found that
code 12 is something got to do with the rpm signal
• No G or NE signal present for 2 seconds during cranking
• Open G circuit
and code 24 is no signal from air intake sensor.
Would anyone know how to fix these??
its an AFM 4agze
ndgcpr
Pine Rivers QLD
April 2005
Re: diagnostic codes 12,24 Tue, 29 November 2005 08:22 Go to previous messageGo to next message
does the car run? the 12 could mean that you have wired it wrong, and thus would not fire properly due to no power when the starter fires.
and the 24 sorta means that the you got an issue with your air intake.
chug
October 2005
Re: diagnostic codes 12,24 Tue, 29 November 2005 08:58 Go to previous messageGo to next message
yep it runs, but bogs really bad under 3000rpm. tryin to fix this problem by starting with the diagnostic codes.
so theres a problem with the AFM?
sometimes when i turn the key to start the car, there's like a 2 sec silence then the car starts would this be related to code 12?
myne
October 2005
Re: diagnostic codes 12,24 Tue, 29 November 2005 09:32 Go to previous messageGo to next message
"RPM SIGNAL-NO SIGNAL TO ECU FROM DISTRIBUTOR ("Ne" OR "G") AFTER ENGINE HAS BEEN CRANKED"
Check
--DISTRIBUTOR/CIRCUIT
--STARTERSIGNAL CIRCUIT
--IGNITER/IGNITER CIRCUIT
--ECU
Going by that, the ecu doesnt know how fast the engine is spinning. I'm suprised it even runs - really it shouldnt. Limp mode must be quite well coded.
chug
October 2005
Re: diagnostic codes 12,24 Tue, 29 November 2005 14:39 Go to previous message
i've did another check, everything seems to be running fine.
the codes were probably saved from previous problems that were solved. my bad
Previous Topic:ARB Air locker for MA70 supra (G series diff)
Next Topic:Microtech Mapped for 2TGEU or 3TGTE
Current Time: Wed Oct 28 13:08:17 UTC 2026
Total time taken to generate the page: 0.0090439319610596 seconds
