Toymods » Tech & Conversions » 98 mr2, no ignition key
syncro
ireland
98 mr2, no ignition key Wed, 30 November 2005 19:35 Go to next message
ive been offered a badly damaged mr2 with the 3sge beams engine, i want to put the engine in my 1981 ke70 corolla using the beams loom and ecu but i noticed that the mr2 ignition barrel has an imobiliser, the keys are not with the car so can i just order a new one from the chassis number from the dealer and does it need to be re coded
Hunty
Re: 98 mr2, no ignition key Fri, 02 December 2005 02:58 Go to previous messageGo to next message
errr why not use the barel from the ke?
syncro
ireland
Re: 98 mr2, no ignition key Sun, 04 December 2005 10:19 Go to previous messageGo to next message
the key has a coded chip in it and the senser ring around the mr2 ign barrel reads the chip in the key and will imobilise the ecu unless you have the correct key.
i dont plan on using the mr2 ignition at all, i want to tape the key on to the senser ring so the ecu is not imobilised
Re: 98 mr2, no ignition key Sun, 04 December 2005 11:11 Go to previous messageGo to next message
call toyota and ask for a price Wink
Viper_III
Hawthorn, Vic
March 2005
Re: 98 mr2, no ignition key Mon, 05 December 2005 00:55 Go to previous messageGo to next message
Taping the key to the sensor probably wont work.
Most keys dont have a battery in them, and even some that do (commo), only get activated when inserted into the barrel via a coil that runs around it. Kinda a smart idea. But not for you in this case.
For those that dont understand this, a coil of wire is energies aroundt he barrel, which creats a small magentic feild. When the key or anything passes thourgh this coil, a small electrical charge is induced and powers the chip momentarily to send out its 'key' signal.
A better option is to probably remove the lock all to gether, get a wiring diagram and either ground the pin form the ecu or send it what it want to know.
Viper_III
Hawthorn, Vic
March 2005
Re: 98 mr2, no ignition key Mon, 05 December 2005 01:42 Go to previous message
Um, yeah... what he said Razz
(Double Post Rolling Eyes )
[Updated on: Mon, 05 December 2005 01:48]
Previous Topic:Speedo and Odometer questions?
Next Topic:microtech mtx8 for 4agze to run 4age
Current Time: Wed Nov 18 13:23:09 UTC 2026
Total time taken to generate the page: 0.0063371658325195 seconds
