Toymods » Tech & Conversions » Pre pump for surge tank choice?
DRAG-DIS
August 2005
Pre pump for surge tank choice? Thu, 01 December 2005 04:32 Go to next message
Hi people,
Got a 1ggte converted to single VG30 t3 steel wheel turbo. I am setting up the fuel system, and I am wondering what chocie i have for a cost efficient pre pump for the surge tank?
I am running 3/8 lines, with a bosch (vl turbo type) fuel pump, 1 litre surge tank. What pre pump should i use that is not excessive in price?
What has everyone else used? Where have you purchased yours from? Is there a cost efficient item I can get off the shelf?
Thankyou for your help.
Viper_III
Hawthorn, Vic
March 2005
Re: Pre pump for surge tank choice? Thu, 01 December 2005 05:19 Go to previous messageGo to next message
im also interested in this.
with a quick thought, i'd say the pump has to be high flow, low pressure, but most importantly not be a positive displacement pump.
so, what pumps fit this criteria?
[Updated on: Thu, 01 December 2005 05:20]
Re: Pre pump for surge tank choice? Thu, 01 December 2005 05:26 Go to previous messageGo to next message
What car is this for?
DRAG-DIS
August 2005
Re: Pre pump for surge tank choice? Thu, 01 December 2005 05:28 Go to previous messageGo to next message
Its for a hilux.
Yeh it has to be a low low pressure high volume pump, i know you can get some off the shelf but they are 100$ plus and thats expensive.
anyone can help?
EVOSTi
cambo
      no
Re: Pre pump for surge tank choice? Thu, 01 December 2005 05:34 Go to previous messageGo to next message
your fuel setup sounds just like mine. i have a VL EFI pump and a 1 litre surge tank. for my lift pump i was using a 5psi carby pump which i paid $30 trade, they retail for about $50. this was fine supporting 200KW. however as i had the fuel from the return line runing back to the surge tank, i had fuel heating issues on hot days. the fuel would get hot causing the VL pump to die. so i got a bigger lift pump which could flow more than the VL pump and had the return line from the engine go to the tank instead. the lift pump was a high flow carter gold (cant remember specs) its way overkill and cost about $115. so now there is always cool petrol getting to the VL pump.
so i reccomend the carter gold, fairly cheap and flows shit loads.
Viper_III
Hawthorn, Vic
March 2005
Re: Pre pump for surge tank choice? Fri, 02 December 2005 01:18 Go to previous messageGo to next message
i did a search, where did u get yours from?
cant seem to find a manufacturers webpage or distributors
[Updated on: Fri, 02 December 2005 01:19]
EVOSTi
cambo
      no
Re: Pre pump for surge tank choice? Fri, 02 December 2005 05:26 Go to previous message
got mine from rare spares in beverly hills, but that prob doesnt help you much.
Previous Topic:1jz exhaust/intake
Next Topic:Noisy 1J steer pump.replace\repair? part # ?
Current Time: Mon Nov 2 00:15:23 UTC 2026
Total time taken to generate the page: 0.0077300071716309 seconds
