Toymods » Tech & Conversions » Piston Selection Help Needed
CLG
Perth, Western Australia
Piston Selection Help Needed Sun, 19 January 2003 13:57 Go to next message
People,
Need a bit of help finding a piston to match my requirements. I need a piston 78mm in bore (78.048mm to be exact - we're going to run 78's with 1.5" "clearance"!) with a pin height of approximately 25mm.
Pin height (also called compression height)is the distance from the centre of the gudgeon pin to the top of the piston, for those who don't understand, or want to know! Gemini pistons come close, but not close enough. So if anyone can supply any info on other pistons, I'd be greatly appreciative!!!
I've been through the ACL piston and ring catalogue (pp03), so any other suggestion please?
Would also like to stay with a flat top or domed piston at the moment for the sake of compression without having to shave a rare big port head, which are harder to find than a good woman (any hints on where to find one of them too, again would be greatly appreciated, the woman that is!!!).
Clint!
Re: Piston Selection Help Needed Sun, 19 January 2003 22:43 Go to previous messageGo to next message
Honda Accord EL 77mm, comp height 27.5 (go 1mm oversize)
Mazda E series 77mm, comp height 28.6 mm
Isuzu 4XC1 77mm, 28,2mm
As much as it pains me to say it, the Honda one is the closest. Are you sure about that comp height? It's really short....
It also helps if you can tell us what motor the piston is out of.
FWDCelica
sydney,nsw.oz.
Re: Piston Selection Help Needed Mon, 20 January 2003 05:31 Go to previous message
Shocked
Clint,
Check out the Wiseco web site. They have a huge selection and also Custom Built. You can get them in OZ.
"http://www.wiseco.com/second.asp?main=sections/spo rtscompact.html&side=secondsections.html"
T.
Previous Topic:Anyone supercharged a 3S-GE?
Next Topic:Need an ECU wiring diagram for 3SGTE...
Current Time: Fri Nov 20 00:49:40 UTC 2026
Total time taken to generate the page: 0.0067138671875 seconds
