Toymods » Tech & Conversions » 4AGZE
SG-EE100
singapore
September 2005
4AGZE Sat, 03 December 2005 10:56 Go to next message
Hi. Can anyone please tell me if i need to change my current 4gze injector if i want to boost up to 1.5 Bar. I am using a VF35 (STI Turbo) , E-manage Piggy-back ECU, Wrx fuel Pump. Thanks
taitran
Melbourne, West Suburbs
April 2005
Re: 4AGZE Sat, 03 December 2005 12:44 Go to previous messageGo to next message
To run 1.5 bar (22psi) i would advise you to run larger aftermarket injectors to flow enough fuel, so you wont lean out.
Make sure you have good cooling for the engine and intercooler at those boost pressures.
4agte
Toronto, Downtown
Re: 4AGZE Sat, 03 December 2005 16:58 Go to previous messageGo to next message
change to either 7mgte supra injectors that are 440cc but even they may be too small so probably 550cc series 4/5 rx7 13b turbo injectors
edit: the stock gze injectors are only good to about 150rw/kws they are 365cc
[Updated on: Sat, 03 December 2005 16:59]
Slippy
March 2005
Re: 4AGZE Sat, 03 December 2005 21:12 Go to previous messageGo to next message
You will definately need to run larger injectors when talking about that amount of boost. Try and pick up a cheap set of 550cc or 600cc injectors. Your always safer going bigger when it comes to your fuel system!!
4agte
Toronto, Downtown
Re: 4AGZE Sat, 03 December 2005 23:14 Go to previous message
Slippy wrote on Sun, 04 December 2005 08:12
bigger is not allways better 550cc should be pleanty and give you some headroom aswell
Previous Topic:speedo not working in 1992 4x4 hilux 2.8L desiel
Next Topic:Suspension on AE82
Current Time: Fri Oct 30 11:35:53 UTC 2026
Total time taken to generate the page: 0.092339992523193 seconds
