Toymods » Tech & Conversions » 1G-GTE ARM wiring
cat007
Auckland, New Zealand
July 2005
1G-GTE ARM wiring Mon, 05 December 2005 21:59 Go to next message
Hey all,
I've had a search through the threads and have been unable to find what I need.
I need to know, what wire does what on the 1G-GTE AFM.
Hunt
www.supras.co.nz *home to the not so standard 1G-GTE*
cat007
July 2005
Re: 1G-GTE ARM wiring Mon, 05 December 2005 22:01 Go to previous messageGo to next message
Subject should read 1G-GTE AFM wiring! Sorry.
Re: 1G-GTE ARM wiring Mon, 05 December 2005 22:46 Go to previous messageGo to next message
What in particular do you want to know?
Re: 1G-GTE ARM wiring Mon, 05 December 2005 23:02 Go to previous messageGo to next message
Check the Wiring Diagrams in the Repository.
Its a very similar AFM to the 7MGE.
cat007
July 2005
Re: 1G-GTE ARM wiring Mon, 05 December 2005 23:22 Go to previous messageGo to next message
I've got the 7MGE wiring but my main concern is in regards to hooking up the HKS Super AFR.
It as 4 settings:
Hotwire 0-5volt
Hotwire 5-0volt
MAP sensor
Karmen Vortex
My AFM is a flapper door style (as you say, very similar to the 7MGE one how-ever I don't know how to find out if the 1G-GTE uses 0-5 or 5-0 volt operation. The voltage versus flow rate curve of the hot wire sensors is not linear, and I believe the safr has some approximate information built into its chip to compensate for it.
Hunt
Re: 1G-GTE ARM wiring Tue, 06 December 2005 00:26 Go to previous message
The 1GGTE AFM is very similar to the 7MGE as described. It goes from 5-0V range (well, more like ~4.5-0.5V but you get the idea).
Previous Topic:st184 interchangable with st190 rear hub
Next Topic:Fuel pressure = 75PSI...on a stock 4AGE????What are my options for running new fuel lines???
Current Time: Thu Nov 19 03:31:07 UTC 2026
Total time taken to generate the page: 0.0069961547851562 seconds
