Toymods » Tech & Conversions » What would Cause TPS to play up ?
GOLDEN86
June 2005
icon5.gif  What would Cause TPS to play up ? Tue, 06 December 2005 00:53 Go to next message
Hey guys,
I've been trying solve my problem for while now with no luck
I have replaced TPS,Coils&Igntion, Spark plugs, leads are good, fuel pump
It would only rev to 4000 revs and just bounce there and miss throttle sometimes, when i unplug TPS the problem is gone but doesnt run the smoothest
With fuel pump is it ok to have it hooked up to ignition ?
[Updated on: Tue, 06 December 2005 07:51]
hinricp
Re: What would Cause TPS to play up ? Tue, 06 December 2005 01:27 Go to previous messageGo to next message
Check your TPS is set up correctly in terms of its base position, i.e feeler guage between throttle stop. You need this so that you can set your timing in diagnostic mode. If your TPS is not showing the correct diagnostic the ecu will not allow you to set timing.
Should not set fuel pump to ign as it will allow the pump to keep running if you have an accident which stops the motor - use the closed circuit relay
GOLDEN86
June 2005
Re: What would Cause TPS to play up ? Tue, 06 December 2005 01:43 Go to previous messageGo to next message
Im not sure what you mean with feeler gauge bewtween throttle stop so you can do your timming in diagnostic mode ?
i saw in manual how you test if your tps is any good, but i have replaced this one and made no difference.
[Updated on: Tue, 06 December 2005 01:43]
hinricp
Re: What would Cause TPS to play up ? Tue, 06 December 2005 01:57 Go to previous messageGo to next message
Assuming you have a factory ECU, you need to be getting a correct zero position on the TPS so it shows the throttle shut before you can insert the diagnostic link to get it to go in to diagnostic mode. From there you can set idle speed and your ignition timing. If you send me a fax number I can fax you the pages from the manual
GOLDEN86
June 2005
Re: What would Cause TPS to play up ? Tue, 06 December 2005 02:11 Go to previous messageGo to next message
What manual is it from ? one on toymods ?
Possible to scan them ?
Hate setting up faxes here, since 1 phone line
GOLDEN86
June 2005
Re: What would Cause TPS to play up ? Tue, 06 December 2005 07:50 Go to previous messageGo to next message
bump ?
Scorpion
Menai area of Sydney
Re: What would Cause TPS to play up ? Tue, 06 December 2005 12:03 Go to previous message
http://toymods.org.au/Repository/TechDocs/4age_boo k/efi/fi_84.jpg
http://toymods.org.au/Repository/TechDocs/4age_boo k/efi/fi_85.jpg
http://toymods.org.au/Repository/TechDocs/4age_boo k/efi/fi_86.jpg
[Updated on: Tue, 06 December 2005 12:05]
Previous Topic:correct offset for sw20 for 16/17 inch rims?
Next Topic:1J Dumps
Current Time: Thu Nov 19 09:36:23 UTC 2026
Total time taken to generate the page: 0.0048789978027344 seconds
