Toymods » Tech & Conversions » Lexus Parts Into A Toyota
kduong01
Lexus Parts Into A Toyota Tue, 06 December 2005 03:28 Go to next message
Hi All,
I was wondering if its possible to fit a Lexus IS200 steering wheel with airbag to a Toyota JZX100 Chaser? Rolling Eyes
stradlater
Arthurs Creek, Victoria
Re: Lexus Parts Into A Toyota Tue, 06 December 2005 03:32 Go to previous messageGo to next message
Big hammer.. Anything should be possible. Just watch the airbag doesn't go off whilst your hammering it.
Could be messy.
kduong01
Re: Lexus Parts Into A Toyota Tue, 06 December 2005 03:40 Go to previous messageGo to next message
Will the wiring fit straight up though? Confused
ChuckLandwehr
Re: Lexus Parts Into A Toyota Tue, 06 December 2005 23:51 Go to previous messageGo to next message
Toyota is not reknown for re-inventing the wheel. If it works, they stick with it. Chances are that if the year models of both cars are close, then the wiring would be the same. You could almost guarantee that the steering shaft will match.
You could probably get hold of the wiring diagrams for both cars, and cross check, before you purchase the wheel.
cheers Chuck.
Jonny2TG
Tasmania
Re: Lexus Parts Into A Toyota Wed, 07 December 2005 08:06 Go to previous message
the first old airbags, that were on SDV10 Camrys were mechanical, no wires. But a rod needs to be pulled to disable it before pulling off.
All other new airbags are electric, and have a "clock spring" wire from the colum to the steering wheel. It allows for about 5 turns lock to lock. So turn it 2.5 turns from the end to get the spring centralised. Its best to diconnect the battery and wait 30 seconds before pulling on it too hard. Be carefull with the yellow connector plug, this is the bit that needs to be the same on both vehicles, unless you rewire a plug.
Previous Topic:1JZ head gasket
Next Topic:Identify my T50 please!
Current Time: Thu Nov 19 08:41:31 UTC 2026
Total time taken to generate the page: 0.0058109760284424 seconds
