Toymods » Tech & Conversions » Auto Radiator oil cooling
DacBietAE86
Auto Radiator oil cooling Tue, 06 December 2005 05:10 Go to next message
Hey guys..
i have a nissan radiator which came from an auto vehicle so it has the transmission cooler in the bottom endtank
What do u guys rekon
Could you plumb up the oil cooler lines to the radiator..
Would it be any good?
September_Squall
Melbourne, Australia
March 2005
Re: Auto Radiator oil cooling Tue, 06 December 2005 05:19 Go to previous messageGo to next message
DacBietAE86 wrote on Tue, 06 December 2005 16:10
No.
No. Unless you like oil leaking out of your engine like a sieve thorugh the radiator, in which case it'll be very good.
the fittings aren't designed for full-flow engine oil - but it might work for a cooling setup that just drains to the sump (e.g. low pressure) if it sits at the right height.
if it were mine, i'd remove the cooler from the lower tank to increase the volume of cool water at the bottom of the radiator.
cressida_1jz
On Probation
Re: Auto Radiator oil cooling Tue, 06 December 2005 12:03 Go to previous messageGo to next message
Removing the o/c from the bottom tank will do stuff all to coolant capacity.
Plus if its a plastic tank,you cant plug the holes up.If its a brass tank,you can remove and solder a patch on the holes but the o/c is silver soldered on and a labour intensive job.In other words"leave it in"
Does your car have p/s?if so,run the p/s fluid through there.
MR 1JZ
Re: Auto Radiator oil cooling Thu, 08 December 2005 05:47 Go to previous message
cressida_1jz wrote on Tue, 06 December 2005 22:33
I did this with a commodore radiator that I had in the soarer previously, worked a treat, makes more room for an FMIC when you remove the pesky PS lines that are convetionally for cooling also Smile
Previous Topic:I am Working a 3sge Gen 1, What would u do?
Next Topic:colder thermostat 4age
Current Time: Wed Nov 18 23:09:29 UTC 2026
Total time taken to generate the page: 0.0044620037078857 seconds
