Toymods » Tech & Conversions » 7MGTE - drivabliity probs
stealth007008
perth
June 2005
7MGTE - drivabliity probs Sat, 10 December 2005 00:38 Go to next message
ill enlighten u with my dilemma. say ya cruising down the street under constant acceleration maintaining 5 psi boost the u slightly easy of the throttle so that the car runs into vacuum - then the cars stutters and stubles just slightly but ebought to piss me off.. its also got a slight "hunt" at idle once the cars warmed up wich ive gotten used to just doesnt sound right and occasionally the car will stall (more often when its warm alos. ive removed and blocked the bov incase it was leaking or because it vents to atmoshpere - makes no diff. i got lexus afm 550cc pod ehaust intercoller safc tuned by the faggots at hyperdrive.. ive also tried another tps which made no diff either. any clues as to what my prob may be... cheers
[Updated on: Sun, 11 December 2005 01:04]
Re: 7MGTE - do u need a rising rate fuel pressure reg to make the lexus reimer work Sat, 10 December 2005 00:45 Go to previous messageGo to next message
No.
1200det
Re: 7MGTE - do u need a rising rate fuel pressure reg to make the lexus reimer work Sat, 10 December 2005 07:21 Go to previous messageGo to next message
i use a adjustable fuel pressure reg due to having a walbro and 550cc injectors but i dont use a rising rate pressure reg
Karma Supra
Henley-on-Thames, England
August 2005
Re: 7MGTE - do u need a rising rate fuel pressure reg to make the lexus reimer work Sun, 11 December 2005 00:02 Go to previous message
No Wink
Even with a walbro you can get away without!!!
Previous Topic:Just bought an RA65
Next Topic:4AGE 16V Coil Problem
Current Time: Wed Nov 18 14:14:50 UTC 2026
Total time taken to generate the page: 0.0046119689941406 seconds
